[Mapserver-users] Mandrake 9 mapserver install problems
Vincent Schut
schut at sarvision.com
Fri Apr 25 07:42:44 EDT 2003
In addition to my previous mail:
probably the correct command to catch your make output into a text file is:
make 2>&1 | tee make_output.txt
You could try that.
Regards,
Vincent.
On Friday 25 April 2003 12:50, Mark Balman wrote:
> Hi List
> Attached is the output from my failed make (using ./configure --with-proj
> --with-gdal) on Mandrake 9.0 and using mapserver 3.6.4.
> Any comments and hints would be greatly appreciated!
> TIA
> Mark
> <<make_out.txt>>
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
