Fw: [Mapserver-users] set filter with cgi
Alessandro Galasso agalasso at gndci.cs.cnr.it
Mon Apr 28 11:51:37 EDT 2003
Hi Babak,
in MS 3.6 I only set FILTERITEM without FILTER for a give layer.
In the cgi querystring, then, i use this:
http://laplace/mapserver/mapserv.exe
?map=calabria/calabria.map
&imgsize=863+384
&qlayer=myLayer
&mode=itemquerymap
&map_myLayer_filter=COSENZA
and everything's right.
Unfortunately i tried to use the same syntax with 3.7 version and obtain an
error:
msQueryByAttributes(): Query error. No query expression defined.
i don't know why.... if someone does I'll appreciate any hint and/or
clarification...
Alessandro Galasso
> ----- Original Message -----
> From: <babak.tehrani at geosysnet.de>
> To: <Mapserver-users at lists.gis.umn.edu>
> Sent: Monday, April 28, 2003 12:32 PM
> Subject: [Mapserver-users] set filter with cgi
> > Hello,
> > Is it possible to change a layer-FILTER as CGI-URL. In the mapfile I
> > write something like
> >   FILTERITEM "NAME"
> >   FILTER /Germany|France/
> > to display only this two polygons. What I have to write in the mapfile
> > for an empty inital query and how can I set the filter via URL??
/cgi-bin/mapserv.exe?map=c:/path/to/europa.map&amp;mode=map&amp;map_mylayern
> ame_filter=/Germany|France/
> > or ... map_mylayername_filter="/Germany|France/"
> > Thanks for help,
> > babak
> > Mapserver-users mailing list
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
