[Mapserver-users] GTiff/RGB-Output resulting in yellow image
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 29 09:05:48 EDT 2003
Oliver Wesp wrote:
> The image that is written turns out to be completly covered by a yellow
> layer on top of it, with the actual mapfeatures shining through (checked
> with ArcView 3.2, Photoshop6).
> Maybe this is general problem with geotiff. Randy James mentioned
> similar problems with GeoTiff as raster input earlier
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0301/msg00508.html
> Here's my setup:
> Mapserver 3.7 - nightly
> GDAL-cvs-030226
> GD-2.0.11
Oliver,
I would strong encourage people to upgrade to GD 2.0.12. It fixes some
serious issues with transparency. GD 2.0.12 should be consider our minimum
required GD from here on in.
However, I am not convinced it is related to this problem. In Randy's message
he is reprojecting the raster which is a significantly different case than not
doing so. Are you reprojecting?
I think you will need to submit a bug with a minimal map file and data
to reproduce this problem since it does not (apparently) occur with any of
my test cases. If you aren't ready to work up a formal bug report it would
be helpful to see more of your mapfile to see what your background color is,
and various layer options in effect.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
