[Mapserver-users] GTiff/RGB-Output resulting in yellow image
Oliver Wesp wesp at gdv.com
Tue Apr 29 10:05:59 EDT 2003
first of all thanks for your response. In fact I'm reprojecting the data so
maybe this is the point. I'm using GD 2.0.12 now with the same effects as
mentioned. I'm looking into getting a small project together and to submit
a bug.
best regards
Oliver
At 09:05 29.04.2003 -0400, Frank Warmerdam wrote:
>Oliver Wesp wrote:
>>The image that is written turns out to be completly covered by a yellow
>>layer on top of it, with the actual mapfeatures shining through (checked
>>with ArcView 3.2, Photoshop6).
>>Maybe this is general problem with geotiff. Randy James mentioned similar
>>problems with GeoTiff as raster input earlier
>>http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0301/msg00508.html ).
>>Here's my setup:
>>Mapserver 3.7 - nightly
>>GDAL-cvs-030226
>>GD-2.0.11
>Oliver,
>I would strong encourage people to upgrade to GD 2.0.12.  It fixes some
>serious issues with transparency.  GD 2.0.12 should be consider our minimum
>required GD from here on in.
>However, I am not convinced it is related to this problem.  In Randy's message
>he is reprojecting the raster which is a significantly different case than not
>doing so.  Are you reprojecting?
>I think you will need to submit a bug with a minimal map file and data
>to reproduce this problem since it does not (apparently) occur with any of
>my test cases.  If you aren't ready to work up a formal bug report it would
>be helpful to see more of your mapfile to see what your background color is,
>and various layer options in effect.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dipl.-Geogr. Oliver Wesp
Gesellschaft für geografische Datenverarbeitung
Binger Strasse 49-51
D-55218 Ingelheim
fon: +49 6132 714818
fax: +49 6132 714828
http: <http://www.gdv.com>www.gdv.com
