[Mapserver-users] GTiff/RGB-Output resulting in yellow image
Randy James rjames57 at yahoo.com
Tue Apr 29 12:08:20 EDT 2003
Hi
I am using GD 2.0.11 right now. I added the processing
directive to my map file, which seemed to clear up my
problem.
PROCESSING "COLOR_MATCH_THRESHOLD=3"
I could not get the error to show up when using a small
tiff file (small enough to email), so i did not submit a
bug. My tif files are over 160 mb each with a grand total
over 20gb, all loaded with tile index. About half are
reprojected on the fly.
Cheers
Randy
--- Oliver Wesp <wesp at gdv.com> wrote:
> Hi,
> first of all thanks for your response. In fact I'm
> reprojecting the data so
> maybe this is the point. I'm using GD 2.0.12 now with the
> same effects as
> mentioned. I'm looking into getting a small project
> together and to submit
> a bug.
> best regards
> Oliver
> At 09:05 29.04.2003 -0400, Frank Warmerdam wrote:
> >Oliver Wesp wrote:
> >>The image that is written turns out to be completly
> covered by a yellow
> >>layer on top of it, with the actual mapfeatures shining
> through (checked
> >>with ArcView 3.2, Photoshop6).
> >>Maybe this is general problem with geotiff. Randy James
> mentioned similar
> >>problems with GeoTiff as raster input earlier
>>http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0301/msg00508.html
> >>Here's my setup:
> >>Mapserver 3.7 - nightly
> >>GDAL-cvs-030226
> >>GD-2.0.11
> >Oliver,
> >I would strong encourage people to upgrade to GD 2.0.12.
>  It fixes some
> >serious issues with transparency.  GD 2.0.12 should be
> consider our minimum
> >required GD from here on in.
> >However, I am not convinced it is related to this
> problem.  In Randy's message
> >he is reprojecting the raster which is a significantly
> different case than not
> >doing so.  Are you reprojecting?
> >I think you will need to submit a bug with a minimal map
> file and data
> >to reproduce this problem since it does not (apparently)
> occur with any of
> >my test cases.  If you aren't ready to work up a formal
> bug report it would
> >be helpful to see more of your mapfile to see what your
> background color is,
> >and various layer options in effect.
> >Best regards,
> >I set the clouds in motion - turn up   | Frank
> Warmerdam, warmerdam at pobox.com
> >light and sound - activate the windows |
> http://pobox.com/~warmerdam
> >and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> >_______________________________________________
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Dipl.-Geogr. Oliver Wesp
> Gesellschaft für geografische Datenverarbeitung
> Binger Strasse 49-51
> D-55218 Ingelheim
> fon: +49 6132 714818
> fax: +49 6132 714828
> http: <http://www.gdv.com>www.gdv.com
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
