[Mapserver-users] WMS questions
Alessandro Galasso agalasso at gndci.cs.cnr.it
Tue Apr 29 12:56:54 EDT 2003
I can only say to you something about the second problem.
You need to define a projection for the map. Also A WMS layer have to
contain a projection. It may be in this format:
    PROJECTION          #ED50 / UTM zone 33N
      "init=epsg:23033"
    END
Where the init is referred to the epsg code.
Give a look at this site for the available projection-codes:
http://inovagis.dcea.fct.unl.pt/giserver/epsg.asp
Alessandro Galasso
----- Original Message -----
From: "Michael Anderson" <m_anderson14 at hotmail.com>
To: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, April 29, 2003 6:40 PM
Subject: [Mapserver-users] WMS questions
> Hello,
> I have two problems. First, when I make GetCapabilities and GetMap
requests
> to a WMS server using 3.6.3, something is wrong with the response headers.
> My browser won't display the xml or the image, it asks me to select a
> program to open them with. When I open them they are correct. I have 3.6.0
> on my system as well and it works fine. I'm running it under Apache on
> Windows XP. I have 3.6.3 running on a Linux box as well and have the same
> problem.
> The second problem is related to setting up MapServer as a WMS client. I
> added one layer with the WMS connection type, but when I try to render
that
> layer I get this error message:
> msProcessProjection(): Projection library error. no options found in
'init'
> file
> What is the init file it's referring to and what is it supposed to
contain?
> The only references to an init file I could find in the archives were
about
> demo_init.html.
> Thanks.
> Mike
> _________________________________________________________________
> Add photos to your messages with MSN 8. Get 2 months FREE*.
> http://join.msn.com/?page=features/featuredemail
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
