[Mapserver-users] what to do w/ ming swf's?
Charlton Purvis cpurvis at asg.sc.edu
Tue Apr 29 14:44:04 EDT 2003
Thanks for your help, Grant.  But I'm afraid that I'm still in the dark.
I'd like to play w/ flash a bit more even though I'm pretty happy w/
animated .gif's.
But I'm missing how my .php and ActionScript are linked.  First of all,
it's not free, is it?  I'd like to think that I could make ActionScript
calls from w/i my .php, but that ain't so, is it?
So where and in what type of file are calls like
  var mapName = _level10.mapObj.name;
Thanks again.
Charlton
-----Original Message-----
Sent: Wednesday, April 23, 2003 7:08 PM
To: Charlton Purvis
Cc: Mapserver Users (E-mail)
Subject: RE: [Mapserver-users] what to do w/ ming swf's?
Hey Charlton,
I've been working a little with swf output, so I'll do my best to share
what
I know. The ####.swf that you refer too is indeed a control file.
However,
it does not start an animation, it simple contains some actionscript
that
holds info about your returned layers (the *_layer_*.swf's).
For instance, you would load the first swf file into your timeline:
	loadMovieNum("1051023629262321.swf",10);
Once it is loaded, there will now be an object named mapObj that
contains
info, such as the name, width, etc. You can get access to these
properties:
It also contains an array of the returned layers. These layers
themselves
have properties such as name, relative name, etc. You can also access
there
properties:
	var layerName0 = _level10.mapObj.layers[0].name;
Using the "relativeName" property of the layer, you can load the layers
into
movieclips on your timeline:
MyMovieClipLayer.loadMovie(_level10.mapObj.layers[0].relativename);
Once you have all the layers loaded into seperate movie clips, you
should be
able to have some animations run.
I hope this helps clear things up a little..  feel free to contact me
for
more info.
Ryan Grant
rgrant at nrcan.gc.ca
From: Charlton Purvis [mailto:cpurvis at asg.sc.edu]
Sent: Tuesday, April 22, 2003 8:15 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] what to do w/ ming swf's?
Hi, folks:
I'm moving into new territory (for me) w/ animation, and I can't wrap my
hands around exactly what the resulting .swf's are.
I have two layers in my .map file:  one is a raster of elevations, and
the other is are bathymetry lines (LINE).  When I plug in the following
to my .map file:
IMAGETYPE swf
OUTPUTFORMAT
  NAME swf
  DRIVER "SWF"
  MIMETYPE "application/x-shockwave-flash"
  EXTENSION "swf"
  FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
I end up w/ three .swf's in my tmp directory.
1051023629262321.swf         22-Apr-2003 11:11     1k
1051023629262321_layer_0.swf 22-Apr-2003 11:11    78k
1051023629262321_layer_1.swf 22-Apr-2003 11:11    96k
The *_layer_*.swf's are what I would expect, but I thought that the
####.swf would be something like a control file:  click on that, and
away the animation would go (from layer_0 to layer_1).  Yes, this is a
bad example, but it seemed simple, in theory.  But if I click on it, it
produces a blank screen (no errors -- just a blank screen that opens in
a flash player).
Along those same lines, since I want to end up w/ an animation (layer_0,
pause, layer_1, repeat), am I going about it correctly?  Am I
misunderstanding what the ####.swf does and/or can I peek at the
####.swf's contents somehow?
I've used
http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html as a
guide.  Everything works -- I just want to understand what I've got!
Thanks.
Charlton Purvis
(803) 777-8858 : voice
(803) 777-8833 : fax
cpurvis at sc.edu
Advanced Solutions Group
Department of Physics and Astronomy
University of South Carolina
Columbia, SC 29208
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
