[Mapserver-users] WMS questions
Ed McNierney ed at topozone.com
Tue Apr 29 15:11:16 EDT 2003
Mike -
Could you send your MAP file so we can see how things are set up?  Does
your PROJECTION block look EXACTLY like this?
PROJECTION
	"init=epsg:26918"
END
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: (978) 251-4242  Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
From: Michael Anderson [mailto:m_anderson14 at hotmail.com]
Sent: Tuesday, April 29, 2003 2:28 PM
To: agalasso at gndci.cs.cnr.it; Mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] WMS questions
Alessandro,
Thanks for the responses, but I think there are other problems. I think
this
about the header problem for three reasons:
1. It works with 3.6.0, but maybe there was a change with 3.6.3
2. I can send a GetCapabilites request to an ArcIMS server using the WMS
connector and the browser displays it. I think the MIME type for it's
response is application/vnd.org.wms_xml as well.
3. I have the same problem with the gif, png, or jpg images returned
from a
GetMap request
About the WMS client problem, I do have the projection defined at the
map
level in both map files, in the layer in both map files, and as the
"wms_srs" metadata tag in the web object of both map files, even though
all
the data is in the same projection: EPSG:26918. I tried it without
defining
the projection too since they are all the same, but I get the same
error.
Mike
Michael Anderson
Spatial Information Technologies, Inc.
>From: "Alessandro Galasso" <agalasso at gndci.cs.cnr.it>
>To: "Michael Anderson" <m_anderson14 at hotmail.com>
>CC: <Mapserver-users at lists.gis.umn.edu>
>Date: Tue, 29 Apr 2003 19:00:25 +0200
>The first problem arise because the MIME type is
>application/vnd.org.wms_xml. Likely the browser doesn't know it.
>It is not an error... is the norm.
>Alessandro Galasso
>----- Original Message -----
>From: "Michael Anderson" <m_anderson14 at hotmail.com>
>To: <mapserver-users at lists.gis.umn.edu>
>Sent: Tuesday, April 29, 2003 6:40 PM
>Subject: [Mapserver-users] WMS questions
> > Hello,
> > I have two problems. First, when I make GetCapabilities and GetMap
>requests
> > to a WMS server using 3.6.3, something is wrong with the response
>headers.
> > My browser won't display the xml or the image, it asks me to select
a
> > program to open them with. When I open them they are correct. I have
>3.6.0
> > on my system as well and it works fine. I'm running it under Apache
on
> > Windows XP. I have 3.6.3 running on a Linux box as well and have the
>same
> > problem.
> > The second problem is related to setting up MapServer as a WMS
client. I
> > added one layer with the WMS connection type, but when I try to
render
>that
> > layer I get this error message:
> > msProcessProjection(): Projection library error. no options found in
>'init'
> > file
> > What is the init file it's referring to and what is it supposed to
>contain?
> > The only references to an init file I could find in the archives
were
>about
> > demo_init.html.
> > Thanks.
> > Mike
> > _________________________________________________________________
> > Add photos to your messages with MSN 8. Get 2 months FREE*.
> > http://join.msn.com/?page=features/featuredemail
> > Mapserver-users mailing list
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
