[Mapserver-users] Fw: Error installing MapServer
Mario Servin
mservin at tecnoaccion.com.ar
Wed Aug 6 12:52:44 EDT 2003
Dear Mark,
You have the magic powers of Gandalf or you were dealing with IIS a
lot...., you are absolutely right!!!.
That works!, Now I got "No query information to decode. QUERY_STRING not
set. " . When I run the MapServer demo still I got the following
"msLoadMap(): Unable to access file. (C:\Documents and
Settings\mario\MyPages\itasca\demo.map)" but I think it is a minor problem
that I have to deal with, maybe there is something related to spaces in the
folder names.
Thanks a lot an best regards,
Mario
----- Original Message -----
To: "'Mario Servin'" <mservin at tecnoaccion.com.ar>
Sent: Wednesday, August 06, 2003 1:32 PM
Subject: RE: [Mapserver-users] Fw: Error installing MapServer
> Mario,
> You might try copying all the dll's ..... to a folder that is on
everyone's
> path such as c:\winnt\system32.
> IIS runs under it's own user and may not be able to see the programs.
> Just a though.
> Mark
> -----Original Message-----
> From: Mario Servin [mailto:mservin at tecnoaccion.com.ar]
> Sent: Wednesday, August 06, 2003 9:38 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Fw: Error installing MapServer
> From: "Mario Servin" <mservin at tecnoaccion.com.ar>
> To: "Swaminathan, Gayathri" <gayathri at ou.edu>
> Cc: <mailto:mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, August 06, 2003 12:06 PM
> Subject: Re: Error installing MapServer
> > Dear Gayathri,
> > I am a bit of giving up with this!. Finally I could retreive a map
but
> > only from a command prompt console:
> > C:\Program Files\MapServer>mapserv "QUERY_STRING=map=c:\Documents and
> > Settings\mario\MyPages\itasca\demo.map&mode=map"
> > That gave a map and told me :
> > Content-type: image/gif
> > GIF87a ....and all the meaningless characters that correspond to the
> > follow.
> > But, but, FROM the browser there is a big problem!!. I checked the
> logs
> > of my WebServer and find a 502 code that means "bad gateway" that does
not
> > tell me nothing. I suspect that my IIS configuration does not allow the
> > execution of any cgi executable. I am now investigating why this can
> happen.
> This message is intended only for the use of the Addressee and may
> contain information that is PRIVILEGED and CONFIDENTIAL.
> If you are not the intended recipient, you are hereby notified that any
> dissemination of this communication is strictly prohibited. If you have
> received this communication in error, please erase all copies of the
> message and its attachments and notify Space Imaging immediately.
