[Mapserver-users] PNG Annotation Symbol Color Issue
Daniel Morissette
morissette at dmsolutions.ca
Wed Aug 6 13:41:28 EDT 2003
We have noticed a similar color problem in 4.0 with PNG symbols. I
copied your problem description to the bug:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=397
I noticed that a few others have reported colors problems that may or
may not be related. First suggestion to everyone: make sure you don't
have multiple copies of GD or libpng on your system. Once you have
verified that, if you have a simple test case (mapfile and data) to
reproduce the problem then please file a bug in bugzilla and attach the
testcase and steps to reproduce to the bug help us figure the problems.
Thanks
Daniel
Shannon Scott wrote:
> Hello,
> I created an interstate route shield PNG image. I have found that the
> color of the image changes sometimes.
> The issue seems to be related to the percentage of the image covered by
> another color ( green in this example ).
> Has anyone ever seen this before?
> Does anyone know what could cause this?
> I have provided a couple links to help illustrate the issue.
> http://216.220.241.10/images/shield_good.png
> http://216.220.241.10/images/shield_notasgood.png
> It is an issue in 3.6.x and 4.0.
> Thank You for any help or info.
> Shannon
> Apache CGI
> Linux RedHat 8.0
> MN Mapserver 4.0
