[Mapserver-users] Problem for draw map whit oracle Spatial
Tyler Mitchell
TMitchell at lignum.com
Thu Aug 21 11:21:34 EDT 2003
Perhaps you're map EXTENT is not correctly set and you map is not showing
data because it's outside of your coordinate space. Just to clarify, does
it seem you are loading an image for the map and it is just white, or do
you think that it is not loading the image at all?
Tyler
Wilman Rojas
<wilmanrojas at geow
eb.com.co> To
Sent by: mapserver-users at lists.gis.umn.edu
mapserver-users-a cc
dmin at lists.gis.um
n.edu Fax to
Subject
08/20/2003 07:10 [Mapserver-users] Problem for draw
PM map whit oracle Spatial
Hi.
My problem is the next:
Apparently all right work. But the image of map is make in blank.
What problem is?
The next is my map file.
MAP
# Start of map file - created Thu Jan 23 11:06:24 2003
NAME "GENERAL"
STATUS ON
EXTENT 1088625.7777777791 934798.2222222225 1106830.2222222236
951182.2222222225
SIZE 500 500
SYMBOLSET "C:\MapServ\Data\varios\symbols.sym"
FONTSET "C:\MapServ\Data\varios\fonts.txt"
IMAGECOLOR 255 255 255
UNITS METERS
# Start of web interface definition
WEB
IMAGEPATH "C:/MapServ/Output/"
IMAGEURL "/output/"
TEMPLATE "C:/mapserv/website/pruebas/index.html"
END
#WEB
# Start of reference map
REFERENCE
STATUS ON
IMAGE "C:/mapserv/data/sigue/gif/tulua.png"
SIZE 100 75
951182.2222222225
COLOR -1 -1 -1
OUTLINECOLOR 255 14 37
END
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
POSITION UR
SIZE TINY
COLOR 0 0 89
END
END
# Start of scalebar
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS METERS
INTERVALS 5
#LABEL
SIZE 350 5
LABEL
SIZE SMALL
COLOR 0 0 0
END
END
# Start of layer definitions
LAYER
NAME "Zona rural"
STATUS DEFAULT
CONNECTIONTYPE oraclespatial
CONNECTION "system/geoweb at investigacion"
DATA "GEOM from STATES"
TYPE Polygon
CLASS
NAME "Zonas"
COLOR 215 255 233
OUTLINECOLOR 0 0 0
SIZE 1
END
END
END
thank you for Any help.
Wilman Rojas.
Jefe Investigación y Desarrollo.
Geoweb S.A
www.geoweb.com.co
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
