[Mapserver-users] Problem for draw map whit oracle Spatial
Randy James
rjames57 at yahoo.com
Thu Aug 21 11:39:32 EDT 2003
Hi
If you are using windows than the slashes go the other way
\ rather than /
Cheers
Randy
--- Wilman Rojas <wilmanrojas at geoweb.com.co> wrote:
> Hi.
> My problem is the next:
> Apparently all right work. But the image of map is make
> in blank.
> What problem is?
> The next is my map file.
> MAP
> # Start of map file - created Thu Jan 23 11:06:24 2003
> NAME "GENERAL"
> STATUS ON
> EXTENT 1088625.7777777791 934798.2222222225
> 1106830.2222222236
> 951182.2222222225
> SIZE 500 500
> SYMBOLSET "C:\MapServ\Data\varios\symbols.sym"
> FONTSET "C:\MapServ\Data\varios\fonts.txt"
> IMAGECOLOR 255 255 255
> UNITS METERS
> # Start of web interface definition
> WEB
> IMAGEPATH "C:/MapServ/Output/"
> IMAGEURL "/output/"
> TEMPLATE "C:/mapserv/website/pruebas/index.html"
> END
> #WEB
> # Start of reference map
> REFERENCE
> STATUS ON
> IMAGE "C:/mapserv/data/sigue/gif/tulua.png"
> SIZE 100 75
> 1106830.2222222236
> 951182.2222222225
> COLOR -1 -1 -1
> OUTLINECOLOR 255 14 37
> END
> # Start of legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> POSITION UR
> SIZE TINY
> COLOR 0 0 89
> END
> END
> # Start of scalebar
> SCALEBAR
> STATUS ON
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> BACKGROUNDCOLOR 0 0 0
> UNITS METERS
> INTERVALS 5
> #LABEL
> SIZE 350 5
> LABEL
> SIZE SMALL
> COLOR 0 0 0
> END
> END
> # Start of layer definitions
> LAYER
> NAME "Zona rural"
> STATUS DEFAULT
> CONNECTIONTYPE oraclespatial
> CONNECTION "system/geoweb at investigacion"
> DATA "GEOM from STATES"
> TYPE Polygon
> CLASS
> NAME "Zonas"
> COLOR 215 255 233
> OUTLINECOLOR 0 0 0
> SIZE 1
> END
> END
> END
> thank you for Any help.
> Wilman Rojas.
> Jefe Investigación y Desarrollo.
> Geoweb S.A
> www.geoweb.com.co
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
