[Mapserver-users] Mapserver and flash
Yewondwossen Assefa
assefa at dmsolutions.ca
Thu Aug 21 16:02:37 EDT 2003
In you layer movie, there are 2 arrays defined : Attributes and Element.
The Attribues array contains the an entry for each attribute defined
in the SWFDUMPATTRIBUTES metadata. In your case It should be defined like :
nAttributes= 1;
Attributes = new Array();
Attributes[0] = "Name";
The Element array is a mulidimentional array, and contains an entry for
each shape id with values for each attribute. For example for shape id 1
and attribute 0 (1st attribute), the value will be in Element[1][0]. The
first array indice is the shape id and the second indicates the
attribute index.
Later,
PS : If you have access to an SWF decompiler and are able to see the
ActionScript, you should see something like this (generated from my
tests files where SWFDUMPATTRIBUTES" "NAME_E,AREA_KMSQ"):
// Action script...
nAttributes = 2;
Attributes[0] = "NAME_E";
Attributes[1] = "AREA_KMSQ";
Element = new Array();
Element[0] = new Array();
Element[0][0] = "Ellesmere Island National Park Reserve";
Element[0][1] = "39500.000";
Element[1] = new Array();
Element[1][0] = "Aulavik National park";
Element[1][1] = "12200.000";
Geoffrey Rowland wrote:
> Okay, Thanks, I have made the function ElementSelected and can get the
> LayerID,ShapeID, and Event.
> But I'm still at a loss how to get the SWFDUMPATTRIBUTES then? lets say
> my attribute is called Name. how do I get the value using ActionScript?
> Here is what I have so far (just doing this as a test)
> onClipEvent (load) {
> loadMovieNum("state_layer_0.swf",1);
> } onClipEvent(mouseDown) {
> _level1.ElementSelected = function(lid,sid,ev){
> trace("The Layer id is : " + lid);
> trace("The Shape id is : " + sid);
> trace("The event was : " + ev);
> _level1.ElementSelected(LayerId,ShapeId,Event, Name)
> Thanks,
> Geoff
> Yewondwossen Assefa wrote:
>> The way to do it is to use at a layer level a metadata called
>> SWFDUMPATTRIBUTES. The value used for this metadata are the names of
>> the attributes you want to export to the swf file. Please refer to
>> section "How to configure the map file to export attributes" and
>> "Events and Highlights" in the document
>> http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
>> Once the attributes are exported to the swf file, when the user
>> clicks on these objects, there is a mouse event which is triggered and
>> makes an Action Script call to: _root.ElementSelecetd(LayerId,
>> ShapeId, Event). The Flash application who want to receive these
>> events should define the function ElementSelected and use the
>> information receive to do actions like retrieving the attribute values
>> from the specific SWF for the specified shape and display it.
>> Later,
>>> I was playing around with this a bit the other day. Is there a way
>>> to identify features in the swf file? for example if I am displaying
>>> a county layer (from a shapefile), and I want to get the names of the
>>> counties....is that possible using the swf output?
>>> Thanks,
>>> Geoff
>>> William A. Bronsema, C.E.T. wrote:
>>>> Lars-Göran,
>>>> It is fairly easy to view the SWF output using actionscript. Set
>>>> the outputformat in the map file to the following:
>>>> OUTPUTFORMAT
>>>> NAME swf
>>>> MIMETYPE "application/x-shockwave-flash"
>>>> DRIVER swf
>>>> IMAGEMODE PC256
>>>> # the following line is used to output all layers in one swf
>>>> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
>>>> # the following line is used to output all layers individually
>>>> #FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
>>>> END
>>>> After mapserver has generated the temp swf file(s) you can use the
>>>> "loadMovie" actionscript function to load the swf file into a
>>>> pre-existing container. For example, create a new swf file with a
>>>> movie clip called "clip1" and add the following line in actionscript:
>>>> loadMovie ( "http://url/to/swf/mymap.swf", "clip1" );
>>>> I use PHP and php_mapscript to help manage the files on the fly and
>>>> Flash to manage my actionscript.
>>>> I hope this quick overview helps.
>>>> Regards,
>>>> Bill
>>>> Lars-goran Edholm wrote:
>>>>> Hi!
>>>>> Does anybody have an example of using Mapserver with swf vector
>>>>> output.
>>>>> How do i use the swf-actionscript file to view the layers?
>>>>> Mvh
>>>>> Lars-Göran Edholm tel 026/24 14 36
>>>>> 1:e byggnadsinspektör
>>>>> Bygg- och miljökontoret
>>>>> 811 80 Sandviken
>>>>> lars-goran.edholm at sandviken.se
>>>>> _______________________________________________
>>>>> Mapserver-users mailing list
>>>>> Mapserver-users at lists.gis.umn.edu
>>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
