[Mapserver-users] Mapserver and flash (fixed, but new problem)
Geoffrey Rowland
geoffrey.rowland at noaa.gov
Thu Aug 21 16:02:40 EDT 2003
Okay, I finally figured out how to get the attribute data from the SWF
file by using Element. I understand much better now.
However, I am running into a new problem.
I am using phpmapscript to generate the SWF file...
here is a section of my .map file
LAYER
NAME states
METADATA
"DESCRIPTION" "States"
"RESULT_FIELDS" "State_Name"
"SWFDUMPATTRIBUTES" "State_Name"
END
TYPE POLYGON
STATUS ON
DATA states
if i use that, it works fine.
*however* , if i change it ever so slightly to include the population
data in the SWFDUMPATTRIBUTES, it fails and says "failed to render
layer"....this is what causes that error
LAYER
NAME states
METADATA
"RESULT_FIELDS" "State_Name,Pop1999"
"SWFDUMPATTRIBUTES" "State_Name Pop1999"
END
TYPE POLYGON
STATUS ON
DATA states
just adding the Pop1999 field (which contains the population data in the
attribute table).
Here is the entire .map file, maybe I am doing something wrong
# Start of map file
NAME "Pop"
STATUS ON
SIZE 600 600
EXTENT -178.227822 18.913826 -66.949831 71.38269
UNITS dd
SHAPEPATH "data"
IMAGECOLOR 255 255 255
#IMAGETYPE PNG
OUTPUTFORMAT
NAME swf
MIMETYPE "application/x-shockwave-flash"
DRIVER swf
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
WEB
HEADER us_header.html
TEMPLATE temp.html
FOOTER us_footer.html
LOG wnvmapserver.log
MINSCALE 1
MAXSCALE 36335600
IMAGEPATH "d:/Inetpub/maptest/swf/"
IMAGEURL "http://192.168.100.10/maptest/swf/"
METADATA
WMS_TITLE "United States Data"
WMS_ABSTRACT "This is a demonstration of using Mapserver ."
WMS_ACCESSCONSTRAINTS none
WMS_SRS "EPSG:4269"
END # End Metadata
END # End Web
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
LAYER
NAME states
METADATA
END
TYPE POLYGON
STATUS ON
DATA states
CLASSITEM 'Pop1999'
NAME Pop1999
TEMPLATE us_pop.html
CLASS
EXPRESSION ([Pop1999] > 0 and [Pop1999] < 2135252)
COLOR 254 240 217
OUTLINECOLOR 128 128 128
END
CLASS
EXPRESSION ([Pop1999] > 2135251 and [Pop1999] < 4970311)
COLOR 253 212 158
END
CLASS
EXPRESSION ([Pop1999] > 4970310 and [Pop1999] < 9866640)
COLOR 253 187 132
END
CLASS
EXPRESSION ([Pop1999] > 9866639 and [Pop1999] < 20127338)
COLOR 252 141 89
END
CLASS
EXPRESSION ([Pop1999] > 20127337 )
COLOR 227 74 51
END
END # end class
END # end layer
END # end Map File
see anything wrong?
Thanks,
Geoff
Geoffrey Rowland wrote:
> Okay, Thanks, I have made the function ElementSelected and can get the
> LayerID,ShapeID, and Event.
> But I'm still at a loss how to get the SWFDUMPATTRIBUTES then? lets
> say my attribute is called Name. how do I get the value using
> ActionScript?
> Here is what I have so far (just doing this as a test)
> onClipEvent (load) {
> loadMovieNum("state_layer_0.swf",1);
> } onClipEvent(mouseDown) {
> _level1.ElementSelected = function(lid,sid,ev){
> trace("The Layer id is : " + lid);
> trace("The Shape id is : " + sid);
> trace("The event was : " + ev);
> _level1.ElementSelected(LayerId,ShapeId,Event, Name)
> Thanks,
> Geoff
> Yewondwossen Assefa wrote:
>> The way to do it is to use at a layer level a metadata called
>> SWFDUMPATTRIBUTES. The value used for this metadata are the names of
>> the attributes you want to export to the swf file. Please refer to
>> section "How to configure the map file to export attributes" and
>> "Events and Highlights" in the document
>> http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
>> Once the attributes are exported to the swf file, when the user
>> clicks on these objects, there is a mouse event which is triggered
>> and makes an Action Script call to: _root.ElementSelecetd(LayerId,
>> ShapeId, Event). The Flash application who want to receive these
>> events should define the function ElementSelected and use the
>> information receive to do actions like retrieving the attribute
>> values from the specific SWF for the specified shape and display it.
>> Later,
>>> I was playing around with this a bit the other day. Is there a way
>>> to identify features in the swf file? for example if I am
>>> displaying a county layer (from a shapefile), and I want to get the
>>> names of the counties....is that possible using the swf output?
>>> Thanks,
>>> Geoff
>>> William A. Bronsema, C.E.T. wrote:
>>>> Lars-Göran,
>>>> It is fairly easy to view the SWF output using actionscript. Set
>>>> the outputformat in the map file to the following:
>>>> OUTPUTFORMAT
>>>> NAME swf
>>>> DRIVER swf
>>>> IMAGEMODE PC256
>>>> # the following line is used to output all layers in one swf
>>>> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
>>>> # the following line is used to output all layers individually
>>>> #FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
>>>> END
>>>> After mapserver has generated the temp swf file(s) you can use the
>>>> "loadMovie" actionscript function to load the swf file into a
>>>> pre-existing container. For example, create a new swf file with a
>>>> movie clip called "clip1" and add the following line in actionscript:
>>>> loadMovie ( "http://url/to/swf/mymap.swf", "clip1" );
>>>> I use PHP and php_mapscript to help manage the files on the fly and
>>>> Flash to manage my actionscript.
>>>> I hope this quick overview helps.
>>>> Regards,
>>>> Bill
>>>> Lars-goran Edholm wrote:
>>>>> Hi!
>>>>> Does anybody have an example of using Mapserver with swf vector
>>>>> output.
>>>>> How do i use the swf-actionscript file to view the layers?
>>>>> Mvh
>>>>> Lars-Göran Edholm tel 026/24 14 36
>>>>> 1:e byggnadsinspektör
>>>>> Bygg- och miljökontoret
>>>>> 811 80 Sandviken
>>>>> lars-goran.edholm at sandviken.se
>>>>> _______________________________________________
>>>>> Mapserver-users mailing list
>>>>> Mapserver-users at lists.gis.umn.edu
>>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Geoffrey Rowland
Technical Officer
Climate Information Project
NOAA Research
Office of Global Programs
http://www.cip.ogp.noaa.gov
Contractor,
RGII Technologies, Inc., a Computer Horizons Company
http://www.rg2.com
Phone: 301-427-2089x186
Fax : 301-427-2082
