[Mapserver-users] Mapserver and flash (fixed, but new problem)
Yewondwossen Assefa assefa at dmsolutions.ca
Thu Aug 21 16:20:17 EDT 2003
The attributes values should only be separated by a comma
("SWFDUMPATTRIBUTES" "State_Name,Pop1999").
  I am going to check if it is possible to have a better error report if
something invalid is given (Bigt 415 in mapserver bug list)
Later,
Geoffrey Rowland wrote:
> Okay, I finally figured out how to get the attribute data from the SWF
> file by using Element.  I understand much better now.
> However, I am running into a new problem.
> I am using phpmapscript to generate the SWF file...
> here is a section of my .map file
> LAYER
>  NAME states
>  METADATA
>    "DESCRIPTION" "States"
>    "RESULT_FIELDS" "State_Name"
>    "SWFDUMPATTRIBUTES" "State_Name"
>  END
>  TYPE POLYGON
>  STATUS ON
>  DATA states
> if i use that, it works fine.
> *however* , if i change it ever so slightly to include the population
> data in the SWFDUMPATTRIBUTES, it fails and says "failed to render
> layer"....this is what causes that error
> LAYER
>  NAME states
>  METADATA
>    "RESULT_FIELDS" "State_Name,Pop1999"
>    "SWFDUMPATTRIBUTES" "State_Name Pop1999"
>  END
>  TYPE POLYGON
>  STATUS ON
>  DATA states
> just adding the Pop1999 field (which contains the population data in the
> attribute table).
> Here is the entire .map file, maybe I am doing something wrong
> # Start of map file
> NAME "Pop"
> STATUS ON
> SIZE 600 600
> EXTENT -178.227822 18.913826 -66.949831 71.38269
> UNITS dd
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> #IMAGETYPE PNG
> OUTPUTFORMAT
>        NAME swf
>        MIMETYPE "application/x-shockwave-flash"
>        DRIVER swf
>        IMAGEMODE PC256
>        FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
>      END
> WEB
>  HEADER us_header.html
>  TEMPLATE temp.html
>  FOOTER us_footer.html
>  LOG wnvmapserver.log
>  MINSCALE 1
>  MAXSCALE 36335600
>  IMAGEPATH "d:/Inetpub/maptest/swf/"
>  IMAGEURL "http://192.168.100.10/maptest/swf/"
>  METADATA
>   WMS_TITLE "United States Data"
>   WMS_ABSTRACT "This is a demonstration of using Mapserver ."
>   WMS_ACCESSCONSTRAINTS none
>   WMS_SRS "EPSG:4269"
>  END # End Metadata
> END # End Web
> QUERYMAP
>  SIZE 200 200
>  STATUS ON
>  STYLE HILITE
>  COLOR 255 0 0
> END
> # Start of legend
> LEGEND
>  KEYSIZE 18 12
>  LABEL
>    TYPE BITMAP
>    SIZE MEDIUM
>    COLOR 0 0 89
>  END
>  STATUS ON
> END
> # Start of scalebar
> SCALEBAR
>  LABEL
>    COLOR 255 255 255
>    SIZE tiny    END
>  STYLE 1
>  SIZE 80 2
>  COLOR 255 255 255
>  UNITS MILES
>  INTERVALS 1
>  TRANSPARENT TRUE
>  STATUS TRUE
> END
> LAYER
>  NAME states
>  METADATA
>  END
>  TYPE POLYGON
>  STATUS ON
>  DATA states
> CLASSITEM 'Pop1999'
> NAME Pop1999
> TEMPLATE us_pop.html
> CLASS
>  EXPRESSION ([Pop1999] > 0 and [Pop1999] < 2135252)
>  COLOR 254 240 217
>  OUTLINECOLOR 128 128 128
> END
> CLASS
>  EXPRESSION ([Pop1999] >   2135251 and [Pop1999] < 4970311)
>  COLOR 253 212 158
> END
> CLASS
>  EXPRESSION ([Pop1999] > 4970310 and [Pop1999] < 9866640)
>  COLOR 253 187 132
> END
> CLASS
>  EXPRESSION ([Pop1999] > 9866639 and [Pop1999] < 20127338)
>  COLOR 252 141 89
> END
> CLASS
>  EXPRESSION ([Pop1999] >   20127337 )
>  COLOR 227 74 51
> END
> END # end class
> END # end layer
> END # end Map File
> see anything wrong?
> Thanks,
> Geoff
>> Okay, Thanks, I have made the function ElementSelected and can get the
>> LayerID,ShapeID, and Event.
>> But I'm still at a loss how to get the SWFDUMPATTRIBUTES then?  lets
>> say my attribute is called Name.  how do I get the value using
>> ActionScript?
>> Here is what I have so far (just doing this as a test)
>> onClipEvent (load) {
>>        loadMovieNum("state_layer_0.swf",1);
>> }   onClipEvent(mouseDown) {
>>    _level1.ElementSelected = function(lid,sid,ev){
>>             trace("The Layer id is : " + lid);
>>             trace("The Shape id is : " + sid);
>>             trace("The event was : " + ev);
>>        _level1.ElementSelected(LayerId,ShapeId,Event, Name)
>> Thanks,
>> Geoff
>> Yewondwossen Assefa wrote:
>>> The way to do it is to use at a layer level a metadata called
>>> SWFDUMPATTRIBUTES. The value used for this metadata are the names of
>>> the attributes you want to export to the swf file. Please refer to
>>> section "How to configure the map file to export attributes"  and
>>> "Events and Highlights" in the document
>>> http://www2.dmsolutions.ca/mapserver/dl/FlashMapserverUserDoc.html
>>>  Once the attributes are exported to the swf file, when the user
>>> clicks on these objects, there is a mouse event which is triggered
>>> and makes an Action Script call to: _root.ElementSelecetd(LayerId,
>>> ShapeId, Event). The Flash application who want to receive these
>>> events should define the function ElementSelected and use the
>>> information receive to do actions like retrieving the attribute
>>> values from the specific SWF for the specified shape and display it.
>>> Later,
>>>> I was playing around with this a bit the other day.  Is there a way
>>>> to identify features in the swf file?  for example if I am
>>>> displaying a county layer (from a shapefile), and I want to get the
>>>> names of the counties....is that possible using the swf output?
>>>> Thanks,
>>>> Geoff
>>>> William A. Bronsema, C.E.T. wrote:
>>>>> Lars-Göran,
>>>>> It is fairly easy to view the SWF output using actionscript.  Set
>>>>> the outputformat in the map file to the following:
>>>>>   OUTPUTFORMAT
>>>>>     NAME swf
>>>>>     DRIVER swf
>>>>>     IMAGEMODE PC256
>>>>>     # the following line is used to output all layers in one swf
>>>>>     FORMATOPTION "OUTPUT_MOVIE=SINGLE"
>>>>>     # the following line is used to output all layers individually
>>>>>     #FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
>>>>>   END
>>>>> After mapserver has generated the temp swf file(s) you can use the
>>>>> "loadMovie" actionscript function to load the swf file into a
>>>>> pre-existing container.  For example, create a new swf file with a
>>>>> movie clip called "clip1" and add the following line in actionscript:
>>>>> loadMovie ( "http://url/to/swf/mymap.swf", "clip1" );
>>>>> I use PHP and php_mapscript to help manage the files on the fly and
>>>>> Flash to manage my actionscript.
>>>>> I hope this quick overview helps.
>>>>> Regards,
>>>>> Bill
>>>>> Lars-goran Edholm wrote:
>>>>>> Hi!
>>>>>> Does anybody have an example of using Mapserver with swf vector
>>>>>> output.
>>>>>> How do i use the swf-actionscript file to view the layers?
>>>>>>  Mvh
>>>>>> Lars-Göran Edholm    tel 026/24 14 36
>>>>>> 1:e byggnadsinspektör
>>>>>> Bygg- och miljökontoret
>>>>>> 811 80 Sandviken
>>>>>> lars-goran.edholm at sandviken.se
>>>>>> _______________________________________________
>>>>>> Mapserver-users mailing list
>>>>>> Mapserver-users at lists.gis.umn.edu
>>>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
