[Mapserver-users] mapscript - queryByPoint help, simple Q
poff
poff at sixbit.org
Thu Aug 28 17:40:42 EDT 2003
> The problem is probably in your map file.
> TEMPLATE belongs in the LAYER not the CLASS.
Thanks, I changed this and no change to the outcome.
However, I added the TEMPLATE tag to all of the layers and then suddenly,
on the last layer:
Warning: MapServer Error in msOpenSHPFile(): No (NULL) filename provided
This is using $mapObj->query...
With the $uLayer->query it just says no records.
Then when I changed $uLayer to the last one they both give the NULL error.
I'll go bald with all this hair pulling out!
Thanks,
P
> On Thu, 2003-08-28 at 19:15, poff wrote:
> > Hello again
> > I've tried all the list suggestions with the followig code, but am _still_
> > getting "No Records Found".
> > If anyone could suggest or point out what I'm doing wrong I'd be greatly
> > indebted to them!
> > Here it goes:
> > $map = ms_newMapObj($mapfile);
> > $uLayer = $map->getLayerByName("Points");
> > $uLayer->set("status",1);
> > $image=$map->draw();
> > while () {
> > $oPoint = ms_newPointObj();
> > $oPoint->setXY($geoData['px'], $geoData['py']);
> > $line = ms_newLineObj();
> > $line->add($oPoint);
> > $shp=ms_newShapeObj(MS_SHAPE_POINT);
> > $shp->add($line);
> > $shp->{text}=$geoData['place_name'];
> > $shp->{index}=$i;
> > $uLayer->addFeature($shp);
> > $oPoint->draw($map, $uLayer, $image, 0, $geoData['place_name']);
> > $my_point = ms_newpointObj();
> > $my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]);
> > $map->queryByPoint($my_point, MS_SINGLE, 20);
> > $uLayer->queryByPoint($my_point,MS_SINGLE,-10); // for good measure
> > And the mapfile:
> > LAYER
> > NAME "Points"
> > STATUS ON
> > TYPE POINT
> > LABELCACHE FALSE
> > CLASS
> > NAME "User Marker"
> > SYMBOL "marker"
> > TEMPLATE "dummy"
> > LABEL
> > END
> > END
> > END
> > I'm pretty stumped! I tried by $map-> and $Layer-> queryByPoint to no great
> > joy.
> > Thanks in advance,
> > P
> > poff at sixbit.org
> > SDF Public Access UNIX System - http://sdf.lonestar.org
> > Please do not carbon copy replies to me
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
poff at sixbit.org
