[Mapserver-users] Unique? Was: mapscript - queryByPoint help, simple Q
poff poff at sixbit.org
Fri Aug 29 08:08:07 EDT 2003
Hello
I know everyone is busy - and thanks a lot for your help.
Only, does _no-one_ use querbypoint with php mapscript?
It's a great feature if I could get it working, and definitely something to
go in Wiki someday!
Thanks
P
On Thu, Aug 28, 2003 at 11:40:42PM +0200, poff wrote:
> > The problem is probably in your map file.
> > TEMPLATE belongs in the LAYER not the CLASS.
> Thanks, I changed this and no change to the outcome.
> However, I added the TEMPLATE tag to all of the layers and then suddenly,
> on the last layer:
> Warning: MapServer Error in msOpenSHPFile(): No (NULL) filename provided
> This is using $mapObj->query...
> With the $uLayer->query it just says no records.
> Then when I changed $uLayer to the last one they both give the NULL error.
> I'll go bald with all this hair pulling out!
> Thanks,
> P
> > On Thu, 2003-08-28 at 19:15, poff wrote:
> > > Hello again
> > > I've tried all the list suggestions with the followig code, but am _still_
> > > getting "No Records Found".
> > > If anyone could suggest or point out what I'm doing wrong I'd be greatly
> > > indebted to them!
> > > Here it goes:
> > > $map = ms_newMapObj($mapfile);
> > > $uLayer = $map->getLayerByName("Points");
> > > $uLayer->set("status",1);
> > > $image=$map->draw();
> > > while () {
> > > 	$oPoint = ms_newPointObj();
> > > 	$oPoint->setXY($geoData['px'], $geoData['py']);
> > > 	$line = ms_newLineObj();
> > > 	$line->add($oPoint);
> > >      	$shp=ms_newShapeObj(MS_SHAPE_POINT);
> > >      	$shp->add($line);
> > >      	$shp->{text}=$geoData['place_name'];
> > >       	$shp->{index}=$i;
> > >       	$uLayer->addFeature($shp);
> > > 	$oPoint->draw($map, $uLayer, $image, 0, $geoData['place_name']);
> > > $my_point = ms_newpointObj();
> > > $my_point->setXY($_REQUEST["mapa_x"],$_REQUEST["mapa_y"]);
> > > $map->queryByPoint($my_point, MS_SINGLE, 20);
> > > $uLayer->queryByPoint($my_point,MS_SINGLE,-10); // for good measure
> > > And the mapfile:
> > > LAYER
> > > 	NAME "Points"
> > > 	STATUS ON
> > > 	TYPE POINT
> > > 	LABELCACHE FALSE
> > > 	CLASS
> > > 		NAME "User Marker"
> > > 		SYMBOL "marker"
> > > 	      	TEMPLATE "dummy"
> > > 		LABEL
> > > 		END
> > > 	END
> > > END
> > > I'm pretty stumped! I tried by $map-> and $Layer-> queryByPoint to no great
> > > joy.
> > > Thanks in advance,
> > > P
> > > poff at sixbit.org
> > > SDF Public Access UNIX System - http://sdf.lonestar.org
> > > Please do not carbon copy replies to me
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> poff at sixbit.org
poff at sixbit.org
