[Mapserver-users] Layers hidden.
Wilman Rojas
wilmanrojas at geoweb.com.co
Mon Dec 1 21:39:13 EST 2003
This is a multi-part message in MIME format.
--Boundary_(ID_kipQyjVrW8Qn0qjghyTzxQ)
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: quoted-printable
=20
Why this configuration of map no himself graphic like he is.
Last cape never looks to weigh itself than this on everything.
That explanation there is by this.
=20
This is my map.
=20
MAP
# Start of map file - created Tue Dec 10 15:50:23 2002
NAME "Mapa General de Galicia"
STATUS ON
EXTENT 461786.75 4617318.87 692918.72 4860333.91
SIZE 500 500=20
SYMBOLSET "/home/mapserv/data/varios/symbols2.sym"
FONTSET "/home/mapserv/data/varios/fonts.txt"
IMAGECOLOR 255 255 255
UNITS METERS
# Start of web interface definition
WEB
IMAGEPATH "/home/mapserv/output/"
IMAGEURL "/output/"
#TEMPLATE "/home/mapserv/website/tanger/main.htm"
END
# Start of reference map
REFERENCE
STATUS ON
IMAGE "/home/mapserv/data/galicia/galicia.png"
SIZE 90 75=20
COLOR -1 -1 -1
OUTLINECOLOR 255 51 0
END
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12=20
LABEL
TYPE BITMAP
SIZE TINY
POSITION UR
COLOR 0 0 89
END
END
# Start of scalebar
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS METERS
INTERVALS 5
#LABEL
SIZE 350 5=20
LABEL
SIZE SMALL
COLOR 0 0 0
END
END
# Start of layer definitions
=20
=20
LAYER
NAME "Mapa de Distancias"
STATUS OFF
DATA "the_geom from geo_distancias"
CONNECTIONTYPE POSTGIS
CONNECTION "user=3Dpostgres dbname=3Dgalicia host=3D200.74.148.138
port=3D5432"
TYPE POLYGON
CLASSITEM "rango"
CLASS
EXPRESSION " "
NAME "Rango de Distancias"
COLOR 255 255 255
#OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "35"=20
NAME "35 Km."
COLOR 254 238 225
#OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "70"
NAME "70 Km."
COLOR 254 221 195
#OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "105"
NAME "105 Km."
COLOR 254 205 165
#OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "140"
NAME "140 Km."
COLOR 254 172 105
#OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "175"
NAME "175 Km."
COLOR 254 136 40
#OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "210"
NAME "210 Km."
COLOR 234 105 0
#OUTLINECOLOR 0 0 0
END
END =20
=20
LAYER
NAME "Buffers"
STATUS DEFAULT=20
DATA "/home/mapserv/data/galicia/bufers.shp" =20
TYPE POLYGON
CLASSITEM "color"
CLASS
EXPRESSION " "
NAME "L=EDmites Galicia"
COLOR 255 255 255
END
CLASS
EXPRESSION "1"
COLOR 204 204 153
END
CLASS
EXPRESSION "2"
COLOR 214 213 165
END
CLASS
EXPRESSION "3"
COLOR 215 215 181
END
CLASS
EXPRESSION "4"
COLOR 222 222 188
END
CLASS
EXPRESSION "5"
COLOR 230 230 206
END
CLASS
EXPRESSION "6"
COLOR 238 238 214
END
CLASS
EXPRESSION "7"
COLOR 239 241 230
END
CLASS
EXPRESSION "8"
COLOR 247 247 239
END
CLASS
EXPRESSION "9"
COLOR 102 204 255
END
CLASS
EXPRESSION "10"
COLOR 115 212 255
END
CLASS
EXPRESSION "11"
COLOR 140 215 254
END
CLASS
EXPRESSION "12"
COLOR 156 222 254
END
CLASS
EXPRESSION "13"
COLOR 181 230 255
END
CLASS
EXPRESSION "14"
COLOR 197 238 255
END
CLASS
EXPRESSION "15"
COLOR 218 240 254
END
CLASS
EXPRESSION "16"
COLOR 238 247 254
END
END
=20
LAYER
NAME "sql"
STATUS DEFAULT
DATA "the_geom from (select geo_talleres.oid, geo_talleres.the_geom,
taller_auditoria.cod_taller, taller_auditoria.empleados_fijos,
taller_auditoria.provincia, taller_auditoria.localidad,
taller_auditoria.id_fabrica, case when empleados_fijos >=3D'0' and
empleados_fijos <=3D'15' then '1' when empleados_fijos >'15' and
empleados_fijos <=3D'30' then '2' when empleados_fijos >'30' and
empleados_fijos <=3D'50' then '3' when empleados_fijos >'50' then '4' =
end
as total from geo_talleres inner join taller_auditoria on
(taller_auditoria.cod_taller=3Dgeo_talleres.cod_taller)) as query"
port=3D5432"
TYPE POINT
CLASSITEM "total"
CLASS
EXPRESSION ([total] =3D 5)
NAME "Empleados Fijos"
COLOR 255 255 255
END =20
CLASS
EXPRESSION ([total] =3D 1)
NAME "Menos de 15"
TEMPLATE " "
COLOR 255 0 0
OUTLINECOLOR 0 0 0
SYMBOL "circle"
SIZE 8
END
CLASS
EXPRESSION ([total] =3D 2 )
NAME "16 - 30"
TEMPLATE " "
COLOR 255 255 0
OUTLINECOLOR 0 0 0
SYMBOL "circle"
SIZE 8
END
CLASS
EXPRESSION ([total] <=3D 3 )
NAME "31 - 50"
TEMPLATE " "
COLOR 0 0 255
OUTLINECOLOR 0 0 0
SYMBOL "circle"
SIZE 8
END
CLASS
EXPRESSION ([total] =3D 4)
NAME "M=E1s de 51"
TEMPLATE " "
COLOR 0 255 0
OUTLINECOLOR 0 0 0
SYMBOL "circle"
SIZE 8
END
END=20
#Fin
END
=20
Wilman Rojas.
Jefe Investigaci=F3n y Desarrollo.
Geoweb S.A=20
www.geoweb.com.co
Content-type: text/html; charset=iso-8859-1
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3B853.8F91A8B0">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"country-region"/>
<o:SmartTagType =
name=3D"City"/>
<o:SmartTagType =
name=3D"place"/>
<o:SmartTagType =
name=3D"time"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:UseFELayout/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:SimSun;
panose-1:2 1 6 0 3 1 1 1 1 1;
mso-font-alt:\5B8B\4F53;
mso-font-charset:134;
mso-generic-font-family:auto;
mso-font-pitch:variable;
mso-font-signature:3 135135232 16 0 262145 0;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:553679495 -2147483648 8 0 66047 0;}
@font-face
{font-family:"\@SimSun";
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:SimSun;}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
{margin:0cm;
font-size:10.0pt;
font-family:"Courier New";
span.EstiloCorreo18
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EstiloCorreo19
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 3.0cm 70.85pt 3.0cm;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tabla normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]-->
</head>
<body lang=3DES link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal =
style=3D'mso-layout-grid-align:none;text-autospace:none'><font
size=3D2 color=3Dblack face=3DTahoma><span lang=3DEN-US =
style=3D'font-size:10.0pt;
font-family:Tahoma;color:black;mso-ansi-language:EN-US'>Why this =
configuration
of map no himself graphic like he is.<o:p></o:p></span></font></p>
font-family:Tahoma;color:black;mso-ansi-language:EN-US'>Last cape never =
looks
to weigh itself than this on everything.<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 color=3Dblack face=3DTahoma><span =
lang=3DEN-US
style=3D'font-size:10.0pt;font-family:Tahoma;color:black;mso-ansi-languag=
e:EN-US'>That
explanation there is by this.</span></font><font size=3D2 =
face=3DTahoma><span
lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Tahoma;mso-ansi-language:EN-US'><o:=
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><o:p> </o:p></span=
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'>This is my =
map.<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'tab-stops:69.0pt'><font size=3D2 =
color=3Dnavy face=3DArial><span
lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Arial;color:navy;mso-ansi-language:=
EN-US'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
lang=3DEN-US
EN-US'>MAP<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>#<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span># Start of map file - created Tue =
Dec 10 </span></font><st1:time
Hour=3D"15" Minute=3D"50"><font size=3D2 color=3Dnavy face=3DArial><span =
lang=3DEN-US
EN-US'>15:50:23</span></font></st1:time><font
size=3D2 color=3Dnavy face=3DArial><span lang=3DEN-US =
font-family:Arial;color:navy;mso-ansi-language:EN-US'> =
2002<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span></span></font><font size=3D2 =
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>#<o:p></o:p></spa=
n></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><span =
</span>NAME "Mapa General de =
Galicia"<o:p></o:p></span></font></p>
style=3D'font-size:
font-family:Arial;color:navy;mso-ansi-language:EN-US'>STATUS =
ON<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>EXTENT 461786.75 4617318.87 =
692918.72
4860333.91<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>SIZE 500 <span =
class=3DSpellE>500</span> <o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>SYMBOLSET
"/home/mapserv/data/varios/symbols2.sym"<o:p></o:p></span></fon=
t></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>FONTSET =
"/home/mapserv/data/varios/fonts.txt"<o:p></o:p></span></font><=
/p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>IMAGECOLOR 255 <span =
class=3DSpellE>255</span> <span
class=3DSpellE>255</span><o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>UNITS =
METERS<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span># Start of web interface =
definition<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>WEB<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGEPATH "/home/<span =
class=3DSpellE>mapserv</span>/output/"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGEURL =
"/output/"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>#TEMPLATE
"/home/mapserv/website/tanger/main.htm"<o:p></o:p></span></font=
></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>END<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span># Start of reference =
map<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 =
</span>REFERENCE<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>STATUS =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGE "/home/<span =
class=3DSpellE>mapserv/data/galicia/galicia.png</span>"<o:p></o:p></=
span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>SIZE 90 75 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>EXTENT 461786.75 4617318.87 =
692918.72
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>COLOR -1 -1 =
-1<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>OUTLINECOLOR 255 51 =
0<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span># Start of =
legend<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
</span>LEGEND<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>KEYSIZE 18 12 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 =
</span>LABEL<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>TYPE =
BITMAP<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>SIZE =
TINY<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>POSITION =
</span></font><st1:City><st1:place><font
font-family:Arial;color:navy;mso-ansi-language:EN-US'>UR</span></font></s=
t1:place></st1:City><font
font-family:Arial;color:navy;mso-ansi-language:EN-US'><o:p></o:p></span><=
/font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 0 <span =
class=3DSpellE>0</span> 89<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span># Start of <span =
class=3DSpellE>scalebar</span><o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
</span>SCALEBAR<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>COLOR 255 <span =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>OUTLINECOLOR 0 <span =
class=3DSpellE>0</span> <span
class=3DSpellE>0</span><o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>BACKGROUNDCOLOR 0 <span =
<span class=3DSpellE>0</span><o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGECOLOR 255 <span =
<span class=3DSpellE>255</span><o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>UNITS =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>INTERVALS =
5<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
</span>#LABEL<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>SIZE 350 5 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
SMALL<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span># Start of layer =
definitions<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
color=3Dnavy
n></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
</span>LAYER<o:p></o:p></span></font></p>
style=3D'font-size:
</span>NAME "Mapa de Distancias"<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span></span></font><font
OFF<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>DATA "<span =
class=3DSpellE>the_geom</span>
from <span =
class=3DSpellE>geo_distancias</span>"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CONNECTIONTYPE =
POSTGIS<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CONNECTION =
"user=3D<span class=3DSpellE>postgres</span>
<span =
class=3DSpellE>dbname</span>=3D</span></font><st1:country-region><st1:pla=
ce><span
class=3DSpellE><span class=3DGramE><font size=3D2 color=3Dnavy =
face=3DArial><span
lang=3DEN-US =
EN-US'>galicia</span></font></span></span></st1:place></st1:country-regio=
n><font
port=3D5432"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>TYPE =
POLYGON<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CLASSITEM "<span =
class=3DSpellE>rango</span>"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
</span>CLASS<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>EXPRESSION " =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME "<span =
class=3DSpellE>Rango</span>
de <span =
class=3DSpellE>Distancias</span>"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 255 <span =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0</span>#OUTLINECOLOR 0 <span =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>EXPRESSION =
"35" <o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME "35 =
Km."<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 238 =
225<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>#OUTLINECOLOR 0 <span =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"70"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME "70 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 221 =
195<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"105"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME "105 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 205 =
165<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"140"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME "140 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 172 =
105<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"175"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME "175 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 136 =
40<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"210"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME "210 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 234 105 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>END<span =
lang=3DEN-US
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0 =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>NAME =
"Buffers"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>STATUS DEFAULT =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>DATA "/home/<span =
class=3DSpellE>mapserv/data/galicia/bufers.shp</span>"<span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CLASSITEM =
"color"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
class=3DSpellE>L=EDmites</span>
</span></font><st1:country-region><st1:place><font size=3D2 color=3Dnavy
color:navy;mso-ansi-language:EN-US'>Galicia</span></font></st1:place></st=
1:country-region><font
font-family:Arial;color:navy;mso-ansi-language:EN-US'>"<o:p></o:p></=
span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"1"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 204 <span =
class=3DSpellE>204</span>
153<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"2"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 214 213 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"3"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 215 <span =
class=3DSpellE>215</span>
181<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"4"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 222 <span =
class=3DSpellE>222</span>
188<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"5"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 230 <span =
class=3DSpellE>230</span>
206<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"6"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 238 <span =
class=3DSpellE>238</span>
214<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"7"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 239 241 =
230<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"8"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 247 <span =
class=3DSpellE>247</span>
239<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"9"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 102 204 =
255<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"10"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 115 212 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"11"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 140 215 =
254<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"12"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 156 222 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"13"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 181 230 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"14"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 197 238 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"15"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 218 240 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
"16"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 238 247 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>LAYER<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>NAME "<span =
class=3DSpellE>sql</span>"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
DEFAULT<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
from (select <span class=3DSpellE>geo_talleres.oid</span>, <span =
class=3DSpellE>geo_talleres.the_geom</span>,
<span class=3DSpellE>taller_auditoria.cod_taller</span>, <span =
class=3DSpellE>taller_auditoria.empleados_fijos</span>,
<span class=3DSpellE>taller_auditoria.provincia</span>, <span =
class=3DSpellE>taller_auditoria.localidad</span>,
<span class=3DSpellE>taller_auditoria.id_fabrica</span>, case when <span
class=3DSpellE>empleados_fijos</span> >=3D'0' and <span =
<=3D'15' then '1' when <span class=3DSpellE>empleados_fijos</span> =
>'15' and <span
class=3DSpellE>empleados_fijos</span> <=3D'30' then '2' when <span =
>'30' and <span class=3DSpellE>empleados_fijos</span> <=3D'50' =
then '3' when <span
class=3DSpellE>empleados_fijos</span> >'50' then '4' end as total =
from <span
class=3DSpellE>geo_talleres</span> inner join <span =
class=3DSpellE>taller_auditoria</span>
on (<span class=3DSpellE>taller_auditoria.cod_taller</span>=3D<span =
class=3DSpellE>geo_talleres.cod_taller</span>))
as query"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
<span =
ce><span
face=3DArial><span
lang=3DEN-US =
n><font
lang=3DEN-US
EN-US'><span
POINT<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
"total"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>EXPRESSION ([total] =3D =
5)<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>NAME "<span =
class=3DSpellE>Empleados</span>
<span class=3DSpellE>Fijos</span>"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>COLOR 255 <span =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>END<span =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
1)<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
class=3DSpellE>Menos</span>
de 15"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>TEMPLATE " =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>COLOR 255 0 <span =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>OUTLINECOLOR 0 <span =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>SYMBOL =
"circle"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>SIZE =
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>EXPRESSION ([total] =3D =
<span class=3DGramE>2
)</span><o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>NAME "16 - =
30"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
class=3DSpellE>255</span> 0<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
<=3D <span
class=3DGramE>3 )</span><o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>NAME "31 - =
50"<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>COLOR 0 <span =
class=3DSpellE>0</span> 255<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
4)<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span></span></font><font =
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>NAME
"M=E1s de 51"<o:p></o:p></span></font></p>
style=3D'font-size:
</span>TEMPLATE " "<o:p></o:p></span></font></p>
style=3D'font-size:
</span>COLOR 0 255 0<o:p></o:p></span></font></p>
style=3D'font-size:
</span></span></font><font size=3D2 color=3Dnavy face=3DArial><span =
lang=3DEN-US
EN-US'>OUTLINECOLOR
0 <span class=3DSpellE>0</span> <span =
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
lang=3DEN-US
EN-US'><span
style=3D'mso-spacerun:yes'>=A0 </span>END <o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'>#Fin<o:p></o:p></span></font></p>
lang=3DEN-US
EN-US'>END<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
<p class=3DMsoPlainText><font size=3D2 face=3D"Courier New"><span =
style=3D'font-size:
10.0pt;mso-no-proof:yes'>Wilman Rojas.<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;mso-no-proof:yes'>Jefe Investigaci=F3n y =
Desarrollo.<o:p></o:p></span></font></p>
lang=3DEN-US
style=3D'font-size:10.0pt;mso-ansi-language:EN-US;mso-no-proof:yes'>Geowe=
b S.A <o:p></o:p></span></font></p>
lang=3DEN-US
style=3D'font-size:10.0pt;mso-ansi-language:EN-US;mso-no-proof:yes'>www.g=
eoweb.com.co<o:p></o:p></span></font></p>
</div>
</body>
</html>
--Boundary_(ID_kipQyjVrW8Qn0qjghyTzxQ)--
