[Mapserver-users] Layers hidden.
Andy Green green at fboweb.com
Mon Dec 1 23:26:55 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0122_01C3B862.9C073650
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ok, I=92m guessing horrible translation software :-)
=20
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Wilman
Rojas
Sent: Monday, December 01, 2003 9:39 PM
To: Mapserver List
Subject: [Mapserver-users] Layers hidden.
=20
=20
Why this configuration of map no himself graphic like he is.
Last cape never looks to weigh itself than this on everything.
That explanation there is by this.
=20
This is my map.
=20
MAP
  # Start of map file - created Tue Dec 10 15:50:23 2002
  NAME "Mapa General de Galicia"
  STATUS ON
  EXTENT 461786.75 4617318.87 692918.72 4860333.91
  SIZE 500 500=20
  SYMBOLSET "/home/mapserv/data/varios/symbols2.sym"
  FONTSET "/home/mapserv/data/varios/fonts.txt"
  IMAGECOLOR 255 255 255
  UNITS METERS
  # Start of web interface definition
  WEB
    IMAGEPATH "/home/mapserv/output/"
    IMAGEURL "/output/"
    #TEMPLATE "/home/mapserv/website/tanger/main.htm"
  END
  # Start of reference map
  REFERENCE
    STATUS ON
    IMAGE "/home/mapserv/data/galicia/galicia.png"
    SIZE 90 75=20
    COLOR -1 -1 -1
    OUTLINECOLOR 255 51 0
  END
  # Start of legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12=20
    LABEL
      TYPE BITMAP
      SIZE TINY
      POSITION UR
      COLOR 0 0 89
    END
  END
  # Start of scalebar
  SCALEBAR
    STATUS ON
    COLOR 255 255 255
    OUTLINECOLOR 0 0 0
    BACKGROUNDCOLOR 0 0 0
    UNITS METERS
    INTERVALS 5
    #LABEL
    SIZE 350 5=20
    LABEL
      SIZE SMALL
      COLOR 0 0 0
    END
  END
  # Start of layer definitions
=20
=20
  LAYER
    NAME "Mapa de Distancias"
    STATUS OFF
    DATA "the_geom from geo_distancias"
    CONNECTIONTYPE POSTGIS
    CONNECTION "user=3Dpostgres dbname=3Dgalicia host=3D200.74.148.138
port=3D5432"
    TYPE POLYGON
    CLASSITEM "rango"
    CLASS
      EXPRESSION " "
      NAME "Rango de Distancias"
      COLOR 255 255 255
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "35"=20
      NAME "35 Km."
      COLOR 254 238 225
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "70"
      NAME "70 Km."
      COLOR 254 221 195
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "105"
      NAME "105 Km."
      COLOR 254 205 165
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "140"
      NAME "140 Km."
      COLOR 254 172 105
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "175"
      NAME "175 Km."
      COLOR 254 136 40
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "210"
      NAME "210 Km."
      COLOR 234 105 0
      #OUTLINECOLOR 0 0 0
    END
  END   =20
=20
   LAYER
    NAME "Buffers"
    STATUS DEFAULT=20
    DATA "/home/mapserv/data/galicia/bufers.shp"   =20
    TYPE POLYGON
    CLASSITEM "color"
    CLASS
      EXPRESSION " "
      NAME "L=EDmites Galicia"
      COLOR 255 255 255
    END
    CLASS
      EXPRESSION "1"
      COLOR 204 204 153
    END
    CLASS
      EXPRESSION "2"
      COLOR 214 213 165
    END
    CLASS
      EXPRESSION "3"
      COLOR 215 215 181
    END
    CLASS
      EXPRESSION "4"
      COLOR 222 222 188
    END
    CLASS
      EXPRESSION "5"
      COLOR 230 230 206
    END
    CLASS
      EXPRESSION "6"
      COLOR 238 238 214
    END
    CLASS
      EXPRESSION "7"
      COLOR 239 241 230
    END
    CLASS
      EXPRESSION "8"
      COLOR 247 247 239
    END
    CLASS
      EXPRESSION "9"
      COLOR 102 204 255
    END
    CLASS
      EXPRESSION "10"
      COLOR 115 212 255
    END
    CLASS
      EXPRESSION "11"
      COLOR 140 215 254
    END
    CLASS
      EXPRESSION "12"
      COLOR 156 222 254
    END
    CLASS
      EXPRESSION "13"
      COLOR 181 230 255
    END
    CLASS
      EXPRESSION "14"
      COLOR 197 238 255
    END
    CLASS
      EXPRESSION "15"
      COLOR 218 240 254
    END
    CLASS
      EXPRESSION "16"
      COLOR 238 247 254
    END
  END
=20
  LAYER
    NAME "sql"
    STATUS DEFAULT
    DATA "the_geom from (select geo_talleres.oid, geo_talleres.the_geom,
taller_auditoria.cod_taller, taller_auditoria.empleados_fijos,
taller_auditoria.provincia, taller_auditoria.localidad,
taller_auditoria.id_fabrica, case when empleados_fijos >=3D'0' and
empleados_fijos <=3D'15' then '1' when empleados_fijos >'15' and
empleados_fijos <=3D'30' then '2' when empleados_fijos >'30' and
empleados_fijos <=3D'50' then '3' when empleados_fijos >'50' then '4' =
end
as total from geo_talleres inner join taller_auditoria on
(taller_auditoria.cod_taller=3Dgeo_talleres.cod_taller)) as query"
port=3D5432"
    TYPE POINT
    CLASSITEM "total"
    CLASS
    EXPRESSION ([total] =3D 5)
     NAME "Empleados Fijos"
     COLOR 255 255 255
    END  =20
    CLASS
    EXPRESSION ([total] =3D 1)
     NAME "Menos de 15"
     TEMPLATE " "
     COLOR 255 0 0
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
     END
   CLASS
     EXPRESSION ([total] =3D 2 )
     NAME "16 - 30"
     TEMPLATE " "
     COLOR 255 255 0
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
    END
    CLASS
     EXPRESSION ([total] <=3D 3 )
     NAME "31 - 50"
     TEMPLATE " "
     COLOR 0 0 255
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
    END
    CLASS
     EXPRESSION ([total] =3D 4)
     NAME "M=E1s de 51"
     TEMPLATE " "
     COLOR 0 255 0
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
    END
  END=20
#Fin
END
=20
Wilman Rojas.
Jefe Investigaci=F3n y Desarrollo.
Geoweb S.A=20
www.geoweb.com.co
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3B862.9B43BF40">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
 name=3D"City"/>
<o:SmartTagType =
 name=3D"time"/>
<o:SmartTagType =
 name=3D"date"/>
<o:SmartTagType =
 name=3D"country-region"/>
<o:SmartTagType =
 name=3D"place"/>
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:HyphenationZone>21</w:HyphenationZone>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
   <w:UseFELayout/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
 /* Font Definitions */
 @font-face
	{font-family:Wingdings;
	panose-1:5 0 0 0 0 0 0 0 0 0;
	mso-font-charset:2;
	mso-generic-font-family:auto;
	mso-font-pitch:variable;
	mso-font-signature:0 268435456 0 0 -2147483648 0;}
@font-face
	{font-family:SimSun;
	panose-1:2 1 6 0 3 1 1 1 1 1;
	mso-font-alt:\5B8B\4F53;
	mso-font-charset:134;
	mso-font-signature:3 135135232 16 0 262145 0;}
@font-face
	{font-family:Tahoma;
	panose-1:2 11 6 4 3 5 4 4 2 4;
	mso-font-charset:0;
	mso-generic-font-family:swiss;
	mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
@font-face
	{font-family:"\@SimSun";
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0in;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:SimSun;}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
	{margin:0in;
	font-size:10.0pt;
	font-family:"Courier New";
span.EmailStyle18
	{mso-style-type:personal;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.EmailStyle19
	font-family:Arial;
	color:navy;}
span.EmailStyle21
	{mso-style-type:personal-reply;
	font-family:Arial;
	color:navy;}
@page Section1
	{size:595.3pt 841.9pt;
	margin:70.85pt 85.05pt 70.85pt 85.05pt;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0in 5.4pt 0in 5.4pt;
	mso-para-margin:0in;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
	font-family:"Times New Roman";}
table.Tablanormal
	{mso-style-name:"Tabla normal";
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Ok, I&#8217;m guessing horrible
translation software </span></font><font size=3D2 color=3Dnavy =
face=3DWingdings><span
style=3D'font-size:10.0pt;font-family:Wingdings;mso-ascii-font-family:Ari=
al;
mso-hansi-font-family:Arial;mso-bidi-font-family:Arial;color:navy;mso-cha=
r-type:
symbol;mso-symbol-font-family:Wingdings'><span =
style=3D'mso-char-type:symbol;
mso-symbol-font-family:Wingdings'>J</span></span></font><font size=3D2
style=3D'font-size:10.0pt;font-family:Arial;
color:navy'><o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p>&nbsp;</o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:35.4pt'><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma;mso-fareast-font-family:"Tim=
es New Roman"'>-----Original
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> =
[mailto:mapserver-users-admin at lists.gis.umn.edu] <b><span =
bold'>On Behalf Of </span></b>Wilman Rojas<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> =
</span></font><st1:date
Month=3D"12" Day=3D"1" Year=3D"2003"><font size=3D2 face=3DTahoma><span =
style=3D'font-size:
 10.0pt;font-family:Tahoma;mso-fareast-font-family:"Times New =
Roman"'>Monday,
 December 01, 2003</span></font></st1:date><font size=3D2 =
face=3DTahoma><span
es New Roman"'>
</span></font><st1:time Hour=3D"21" Minute=3D"39"><font size=3D2 =
face=3DTahoma><span
es New Roman"'>9:39
 PM</span></font></st1:time><font size=3D2 face=3DTahoma><span =
style=3D'font-size:
Roman"'><br>
<b><span style=3D'font-weight:bold'>To:</span></b> Mapserver List<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
hidden.</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:35.4pt'><font size=3D3
face=3D"Times New Roman"><span =
style=3D'font-size:12.0pt'><o:p>&nbsp;</o:p></span></font></p>
face=3D"Times New Roman"><span lang=3DES =
style=3D'font-size:12.0pt;mso-ansi-language:
ES'><o:p>&nbsp;</o:p></span></font></p>
<p class=3DMsoNormal =
style=3D'margin-left:35.4pt;mso-layout-grid-align:none;
text-autospace:none'><font size=3D2 color=3Dblack face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma;color:black'>Why this =
configuration
of map no himself graphic like he is.<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;font-family:Tahoma;color:black'>Last cape =
never looks
to weigh itself than this on everything.<o:p></o:p></span></font></p>
color=3Dblack
style=3D'font-size:10.0pt;font-family:Tahoma;color:black'>That
explanation there is by this.</span></font><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'><o:p></o:p></span></font></=
p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p>&nbsp;</o:p></span></fo=
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>This is my =
map.<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:35.4pt;tab-stops:69.0pt'><font =
size=3D2
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>MAP<o:p></o:p></s=
pan></font></p>
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'><span
style=3D'mso-spacerun:yes'>=A0 </span>#<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span># Start of map file - created Tue =
Dec 10 </span></font><st1:time
Hour=3D"15" Minute=3D"50"><font size=3D2 color=3Dnavy face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>15:50:23</span></=
color:navy'> 2002<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span></span></font><font size=3D2 =
color=3Dnavy
face=3DArial><span lang=3DES =
style=3D'font-size:10.0pt;font-family:Arial;color:navy;
mso-ansi-language:ES'>#<o:p></o:p></span></font></p>
color=3Dnavy
mso-ansi-language:ES'><span style=3D'mso-spacerun:yes'>=A0 </span>NAME =
&quot;Mapa
General de Galicia&quot;<o:p></o:p></span></font></p>
color=3Dnavy
mso-ansi-language:ES'><span style=3D'mso-spacerun:yes'>=A0 =
color:navy'>STATUS ON<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>EXTENT 461786.75 4617318.87 =
692918.72
4860333.91<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>SIZE 500 500 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>SYMBOLSET
&quot;/home/mapserv/data/varios/symbols2.sym&quot;<o:p></o:p></span></fon=
t></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>FONTSET
&quot;/home/mapserv/data/varios/fonts.txt&quot;<o:p></o:p></span></font><=
/p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>IMAGECOLOR 255 255 =
255<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>UNITS =
METERS<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span># Start of web interface =
definition<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>WEB<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGEPATH =
&quot;/home/mapserv/output/&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGEURL =
&quot;/output/&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>#TEMPLATE
&quot;/home/mapserv/website/tanger/main.htm&quot;<o:p></o:p></span></font=
></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>END<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span># Start of reference =
map<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>REFERENCE<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>STATUS =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGE =
&quot;/home/mapserv/data/galicia/galicia.png&quot;<o:p></o:p></span></fon=
t></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>SIZE 90 75 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>EXTENT 461786.75 4617318.87 =
692918.72
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>COLOR -1 -1 =
-1<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>OUTLINECOLOR 255 51 =
0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span># Start of =
legend<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>LEGEND<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>KEYSIZE 18 12 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 =
</span>LABEL<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>TYPE =
BITMAP<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span><span
style=3D'mso-spacerun:yes'>=A0=A0</span>SIZE =
TINY<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>POSITION =
</span></font><st1:City><st1:place><font
  color:navy'>UR</span></font></st1:place></st1:City><font size=3D2 =
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'><o:p></o:p></span=
></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 0 0 =
89<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
scalebar<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>SCALEBAR<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>COLOR 255 255 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>OUTLINECOLOR 0 0 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>BACKGROUNDCOLOR 0 0 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>IMAGECOLOR 255 255 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>UNITS =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>INTERVALS =
color=3Dnavy
</span>#LABEL<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>SIZE 350 5 =
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>SIZE =
SMALL<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span># Start of layer =
definitions<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
mso-ansi-language:ES'><o:p>&nbsp;</o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>LAYER<o:p></o:p></span></font></p>
color=3Dnavy
mso-ansi-language:ES'><span style=3D'mso-spacerun:yes'>=A0=A0=A0 =
</span>NAME &quot;Mapa
de Distancias&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color:navy'>STATUS OFF<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>DATA &quot;the_geom from
geo_distancias&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CONNECTIONTYPE =
POSTGIS<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CONNECTION =
&quot;user=3Dpostgres =
dbname=3D</span></font><st1:country-region><st1:place><font
color:navy'>galicia</span></font></st1:place></st1:country-region><font
color:navy'> host=3D200.74.148.138 =
port=3D5432&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>TYPE =
POLYGON<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>CLASSITEM =
&quot;rango&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>CLASS<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>EXPRESSION &quot; =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;Rango de =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 255 255 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>#OUTLINECOLOR 0 0 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>EXPRESSION =
&quot;35&quot; <o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;35 =
Km.&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 238 =
225<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;70&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;70 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 221 =
195<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;105&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;105 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 205 =
165<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;140&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;140 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 172 =
105<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;175&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;175 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 254 136 =
40<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;210&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;210 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 234 105 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>END<span =
</span><o:p></o:p></span></font></p>
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'><o:p>&nbsp;</o:p>=
</span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>NAME =
&quot;Buffers&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>STATUS DEFAULT =
color=3Dnavy
&quot;/home/mapserv/data/galicia/bufers.shp&quot;<span
color=3Dnavy
color=3Dnavy
&quot;color&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>NAME &quot;L=EDmites =
color:navy'>Galicia</span></font></st1:place></st1:country-region><font
color:navy'>&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;1&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 204 204 =
153<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;2&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 214 213 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;3&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 215 215 =
181<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;4&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 222 222 =
188<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;5&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 230 230 =
206<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;6&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 238 238 =
214<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;7&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 239 241 =
230<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;8&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 247 247 =
239<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;9&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 102 204 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;10&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 115 212 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;11&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 140 215 =
254<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;12&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 156 222 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;13&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 181 230 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;14&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 197 238 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;15&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 218 240 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;16&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0 </span>COLOR 238 247 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>LAYER<o:p></o:p></span></font></p>
color=3Dnavy
&quot;sql&quot;<o:p></o:p></span></font></p>
color=3Dnavy
DEFAULT<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>DATA &quot;the_geom from =
(select
geo_talleres.oid, geo_talleres.the_geom, taller_auditoria.cod_taller,
taller_auditoria.empleados_fijos, taller_auditoria.provincia,
taller_auditoria.localidad, taller_auditoria.id_fabrica, case when
empleados_fijos &gt;=3D'0' and empleados_fijos &lt;=3D'15' then '1' when
empleados_fijos &gt;'15' and empleados_fijos &lt;=3D'30' then '2' when
empleados_fijos &gt;'30' and empleados_fijos &lt;=3D'50' then '3' when
empleados_fijos &gt;'50' then '4' end as total from geo_talleres inner =
join
taller_auditoria on =
(taller_auditoria.cod_taller=3Dgeo_talleres.cod_taller)) as =
query&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
POINT<o:p></o:p></span></font></p>
color=3Dnavy
&quot;total&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>EXPRESSION ([total] =3D =
5)<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>NAME &quot;Empleados =
Fijos&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>COLOR 255 255 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>END<span =
color=3Dnavy
color=3Dnavy
1)<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>NAME &quot;Menos de =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>TEMPLATE &quot; =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>COLOR 255 0 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>OUTLINECOLOR 0 0 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>SYMBOL =
&quot;circle&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>SIZE =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 =
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>EXPRESSION ([total] =3D 2 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>NAME &quot;16 - =
30&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
&lt;=3D 3 )<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>NAME &quot;31 - =
50&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>COLOR 0 0 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>EXPRESSION ([total] =3D =
4)<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span></span></font><font =
mso-ansi-language:ES'>NAME &quot;M=E1s de =
51&quot;<o:p></o:p></span></font></p>
color=3Dnavy
mso-ansi-language:ES'><span style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 =
</span>TEMPLATE
&quot; &quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 0 255 0<o:p></o:p></span></font></p>
color=3Dnavy
color:navy'>OUTLINECOLOR 0 0 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>END <o:p></o:p></span></font></p>
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>#Fin<o:p></o:p></=
span></font></p>
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>END<o:p></o:p></s=
pan></font></p>
face=3DArial><span
nt></p>
<p class=3DMsoPlainText style=3D'margin-left:35.4pt'><font size=3D2 =
face=3D"Courier New"><span
lang=3DES =
style=3D'font-size:10.0pt;mso-ansi-language:ES;mso-no-proof:yes'>Wilman
Rojas.<o:p></o:p></span></font></p>
lang=3DES =
style=3D'font-size:10.0pt;mso-ansi-language:ES;mso-no-proof:yes'>Jefe
Investigaci=F3n y Desarrollo.<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;mso-no-proof:yes'>Geoweb S.A =
style=3D'font-size:10.0pt;mso-no-proof:yes'>www.geoweb.com.co<o:p></o:p><=
/span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0122_01C3B862.9C073650--
