[Mapserver-users] Layers with status in on or default. not is visible.
Wilman Rojas wilmanrojas at geoweb.com.co
Tue Dec 2 00:49:55 EST 2003
This is a multi-part message in MIME format.
--Boundary_(ID_83TVniVDsB8mxQnvfPhdjw)
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: quoted-printable
=20
My problem is that i have three layers but the third layer not is
visible and i don't understand why?
=20
This is my map.
=20
MAP
  # Start of map file - created Tue Dec 10 15:50:23 2002
  NAME "Mapa General de Galicia"
  STATUS ON
  EXTENT 461786.75 4617318.87 692918.72 4860333.91
  SIZE 500 500=20
  SYMBOLSET "/home/mapserv/data/varios/symbols2.sym"
  FONTSET "/home/mapserv/data/varios/fonts.txt"
  IMAGECOLOR 255 255 255
  UNITS METERS
  # Start of web interface definition
  WEB
    IMAGEPATH "/home/mapserv/output/"
    IMAGEURL "/output/"
    #TEMPLATE "/home/mapserv/website/tanger/main.htm"
  END
  # Start of reference map
  REFERENCE
    STATUS ON
    IMAGE "/home/mapserv/data/galicia/galicia.png"
    SIZE 90 75=20
    COLOR -1 -1 -1
    OUTLINECOLOR 255 51 0
  END
  # Start of legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12=20
    LABEL
      TYPE BITMAP
      SIZE TINY
      POSITION UR
      COLOR 0 0 89
    END
  END
  # Start of scalebar
  SCALEBAR
    STATUS ON
    COLOR 255 255 255
    OUTLINECOLOR 0 0 0
    BACKGROUNDCOLOR 0 0 0
    UNITS METERS
    INTERVALS 5
    #LABEL
    SIZE 350 5=20
    LABEL
      SIZE SMALL
      COLOR 0 0 0
    END
  END
  # Start of layer definitions
=20
=20
  LAYER
    NAME "Mapa de Distancias"
    STATUS OFF
    DATA "the_geom from geo_distancias"
    CONNECTIONTYPE POSTGIS
    CONNECTION "user=3Dpostgres dbname=3Dgalicia host=3D200.74.148.138
port=3D5432"
    TYPE POLYGON
    CLASSITEM "rango"
    CLASS
      EXPRESSION " "
      NAME "Rango de Distancias"
      COLOR 255 255 255
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "35"=20
      NAME "35 Km."
      COLOR 254 238 225
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "70"
      NAME "70 Km."
      COLOR 254 221 195
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "105"
      NAME "105 Km."
      COLOR 254 205 165
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "140"
      NAME "140 Km."
      COLOR 254 172 105
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "175"
      NAME "175 Km."
      COLOR 254 136 40
      #OUTLINECOLOR 0 0 0
    END
    CLASS
      EXPRESSION "210"
      NAME "210 Km."
      COLOR 234 105 0
      #OUTLINECOLOR 0 0 0
    END
  END   =20
=20
   LAYER
    NAME "Buffers"
    STATUS DEFAULT=20
    DATA "/home/mapserv/data/galicia/bufers.shp"   =20
    TYPE POLYGON
    CLASSITEM "color"
    CLASS
      EXPRESSION " "
      NAME "L=EDmites Galicia"
      COLOR 255 255 255
    END
    CLASS
      EXPRESSION "1"
      COLOR 204 204 153
    END
    CLASS
      EXPRESSION "2"
      COLOR 214 213 165
    END
    CLASS
      EXPRESSION "3"
      COLOR 215 215 181
    END
    CLASS
      EXPRESSION "4"
      COLOR 222 222 188
    END
    CLASS
      EXPRESSION "5"
      COLOR 230 230 206
    END
    CLASS
      EXPRESSION "6"
      COLOR 238 238 214
    END
    CLASS
      EXPRESSION "7"
      COLOR 239 241 230
    END
    CLASS
      EXPRESSION "8"
      COLOR 247 247 239
    END
    CLASS
      EXPRESSION "9"
      COLOR 102 204 255
    END
    CLASS
      EXPRESSION "10"
      COLOR 115 212 255
    END
    CLASS
      EXPRESSION "11"
      COLOR 140 215 254
    END
    CLASS
      EXPRESSION "12"
      COLOR 156 222 254
    END
    CLASS
      EXPRESSION "13"
      COLOR 181 230 255
    END
    CLASS
      EXPRESSION "14"
      COLOR 197 238 255
    END
    CLASS
      EXPRESSION "15"
      COLOR 218 240 254
    END
    CLASS
      EXPRESSION "16"
      COLOR 238 247 254
    END
  END
=20
  LAYER
    NAME "sql"
    STATUS DEFAULT
    DATA "the_geom from (select geo_talleres.oid, geo_talleres.the_geom,
taller_auditoria.cod_taller, taller_auditoria.empleados_fijos,
taller_auditoria.provincia, taller_auditoria.localidad,
taller_auditoria.id_fabrica, case when empleados_fijos >=3D'0' and
empleados_fijos <=3D'15' then '1' when empleados_fijos >'15' and
empleados_fijos <=3D'30' then '2' when empleados_fijos >'30' and
empleados_fijos <=3D'50' then '3' when empleados_fijos >'50' then '4' =
end
as total from geo_talleres inner join taller_auditoria on
(taller_auditoria.cod_taller=3Dgeo_talleres.cod_taller)) as query"
port=3D5432"
    TYPE POINT
    CLASSITEM "total"
    CLASS
    EXPRESSION ([total] =3D 5)
     NAME "Empleados Fijos"
     COLOR 255 255 255
    END  =20
    CLASS
    EXPRESSION ([total] =3D 1)
     NAME "Menos de 15"
     TEMPLATE " "
     COLOR 255 0 0
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
     END
   CLASS
     EXPRESSION ([total] =3D 2 )
     NAME "16 - 30"
     TEMPLATE " "
     COLOR 255 255 0
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
    END
    CLASS
     EXPRESSION ([total] <=3D 3 )
     NAME "31 - 50"
     TEMPLATE " "
     COLOR 0 0 255
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
    END
    CLASS
     EXPRESSION ([total] =3D 4)
     NAME "M=E1s de 51"
     TEMPLATE " "
     COLOR 0 255 0
     OUTLINECOLOR 0 0 0
     SYMBOL "circle"
     SIZE 8
    END
  END=20
#Fin
END
=20
Wilman Rojas.
Jefe Investigaci=F3n y Desarrollo.
Geoweb S.A=20
www.geoweb.com.co
Content-type: text/html; charset=iso-8859-1
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3B864.24812670">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
 name=3D"country-region"/>
<o:SmartTagType =
 name=3D"City"/>
<o:SmartTagType =
 name=3D"place"/>
<o:SmartTagType =
 name=3D"time"/>
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:HyphenationZone>21</w:HyphenationZone>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
   <w:UseFELayout/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
 /* Font Definitions */
 @font-face
	{font-family:SimSun;
	panose-1:2 1 6 0 3 1 1 1 1 1;
	mso-font-alt:\5B8B\4F53;
	mso-font-charset:134;
	mso-generic-font-family:auto;
	mso-font-pitch:variable;
	mso-font-signature:3 135135232 16 0 262145 0;}
@font-face
	{font-family:"\@SimSun";
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0cm;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:SimSun;}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
	{margin:0cm;
	font-size:10.0pt;
	font-family:"Courier New";
span.EstiloCorreo18
	{mso-style-type:personal;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.EstiloCorreo19
	font-family:Arial;
	color:navy;}
span.EstiloCorreo20
	font-family:Arial;
	color:navy;}
span.EstiloCorreo22
	{mso-style-type:personal-reply;
	font-family:Arial;
	color:navy;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
@page Section1
	{size:595.3pt 841.9pt;
	margin:70.85pt 3.0cm 70.85pt 3.0cm;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Tabla normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
	mso-para-margin:0cm;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
	font-family:"Times New Roman";}
table.TableNormal
	{mso-style-name:"Table Normal";
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DES link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p>&nbsp;</o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:35.4pt'><font size=3D2 =
color=3Dnavy
face=3DArial><span lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Arial;
color:navy;mso-ansi-language:EN-US'>My problem is that <span =
class=3DSpellE>i</span>
have three layers but the third layer not is visible and <span =
don't understand why?<o:p></o:p></span></font></p>
lang=3DEN-US
style=3D'font-size:10.0pt;font-family:Arial;color:navy;mso-ansi-language:=
EN-US'><o:p>&nbsp;</o:p></span></font></p>
face=3DArial><span
lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Arial;mso-ansi-language:EN-US'>This=
is my map.<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:35.4pt;tab-stops:69.0pt'><font =
size=3D2
color=3Dnavy face=3DArial><span lang=3DEN-US =
Arial;color:navy;mso-ansi-language:EN-US'><o:p>&nbsp;</o:p></span></font>=
</p>
color=3Dnavy
color:navy;mso-ansi-language:EN-US'>MAP<o:p></o:p></span></font></p>
color=3Dnavy
color:navy;mso-ansi-language:EN-US'><span style=3D'mso-spacerun:yes'>=A0 =
</span>#<o:p></o:p></span></font></p>
color=3Dnavy
</span>#
Start of map file - created Tue Dec 10 </span></font><st1:time =
Hour=3D"15"
Minute=3D"50"><font size=3D2 color=3Dnavy face=3DArial><span =
lang=3DEN-US
EN-US'>15:50:23</span></font></st1:time><font
size=3D2 color=3Dnavy face=3DArial><span lang=3DEN-US =
font-family:Arial;color:navy;mso-ansi-language:EN-US'> =
2002<o:p></o:p></span></font></p>
color=3Dnavy
</span></span></font><font
color:navy'>#<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'><span
style=3D'mso-spacerun:yes'>=A0 </span>NAME &quot;Mapa General de =
Galicia&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span></span></font><font size=3D2 =
color=3Dnavy
color:navy;mso-ansi-language:EN-US'>STATUS =
ON<o:p></o:p></span></font></p>
color=3Dnavy
</span>EXTENT
461786.75 4617318.87 692918.72 4860333.91<o:p></o:p></span></font></p>
color=3Dnavy
</span>SIZE 500 500 <o:p></o:p></span></font></p>
color=3Dnavy
</span>SYMBOLSET =
&quot;/home/mapserv/data/varios/symbols2.sym&quot;<o:p></o:p></span></fon=
t></p>
color=3Dnavy
</span>FONTSET =
&quot;/home/mapserv/data/varios/fonts.txt&quot;<o:p></o:p></span></font><=
/p>
color=3Dnavy
</span>IMAGECOLOR 255 255 255<o:p></o:p></span></font></p>
color=3Dnavy
</span>UNITS METERS<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>#
Start of web interface definition<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>WEB<o:p></o:p></span></font></p>
color=3Dnavy
color:navy;mso-ansi-language:EN-US'><span =
style=3D'mso-spacerun:yes'>=A0=A0=A0
</span>IMAGEPATH =
&quot;/home/mapserv/output/&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>IMAGEURL &quot;/output/&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>#TEMPLATE =
&quot;/home/mapserv/website/tanger/main.htm&quot;<o:p></o:p></span></font=
></p>
color=3Dnavy
</span>END<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>#
Start of reference map<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>REFERENCE<o:p></o:p></span></font></p>
color=3Dnavy
</span>STATUS ON<o:p></o:p></span></font></p>
color=3Dnavy
</span>IMAGE =
&quot;/home/mapserv/data/galicia/galicia.png&quot;<o:p></o:p></span></fon=
t></p>
color=3Dnavy
</span>SIZE 90 75 <o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>EXTENT
color=3Dnavy
</span>COLOR -1 -1 -1<o:p></o:p></span></font></p>
color=3Dnavy
</span>OUTLINECOLOR 255 51 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>#
Start of legend<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>LEGEND<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>KEYSIZE 18 12 <o:p></o:p></span></font></p>
color=3Dnavy
</span>LABEL<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0
</span>TYPE BITMAP<o:p></o:p></span></font></p>
color=3Dnavy
</span>SIZE TINY<o:p></o:p></span></font></p>
color=3Dnavy
</span>POSITION </span></font><st1:City><st1:place><font size=3D2 =
color=3Dnavy
color:navy;mso-ansi-language:EN-US'>UR</span></font></st1:place></st1:Cit=
y><font
font-family:Arial;color:navy;mso-ansi-language:EN-US'><o:p></o:p></span><=
/font></p>
color=3Dnavy
</span>COLOR 0 0 89<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>#
Start of scalebar<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>SCALEBAR<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>COLOR 255 255 255<o:p></o:p></span></font></p>
color=3Dnavy
</span>OUTLINECOLOR 0 0 0<o:p></o:p></span></font></p>
color=3Dnavy
</span>BACKGROUNDCOLOR 0 0 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>INTERVALS 5<o:p></o:p></span></font></p>
color=3Dnavy
</span>#LABEL<o:p></o:p></span></font></p>
color=3Dnavy
</span>SIZE 350 5 <o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>SIZE SMALL<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 0 0 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>#
Start of layer definitions<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'><o:p>&nbsp;</o:p>=
</span></font></p>
color=3Dnavy
</span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0 </span>LAYER<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span>NAME &quot;Mapa de =
Distancias&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0 </span></span></font><font size=3D2 =
color=3Dnavy
OFF<o:p></o:p></span></font></p>
color=3Dnavy
</span>DATA &quot;the_geom from =
geo_distancias&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>CONNECTIONTYPE POSTGIS<o:p></o:p></span></font></p>
color=3Dnavy
</span>CONNECTION &quot;user=3Dpostgres =
dbname=3D</span></font><st1:country-region><st1:place><font
font-family:Arial;color:navy;mso-ansi-language:EN-US'>galicia</span></fon=
t></st1:place></st1:country-region><font
host=3D200.74.148.138 port=3D5432&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>TYPE POLYGON<o:p></o:p></span></font></p>
color=3Dnavy
</span>CLASSITEM &quot;rango&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>CLASS<o:p></o:p></span></font></p>
color=3Dnavy
</span>EXPRESSION &quot; &quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;Rango de Distancias&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>#OUTLINECOLOR 0 0 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;35&quot; <o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;35 Km.&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 254 238 225<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;70&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;70 Km.&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 254 221 195<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;105&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;105 Km.&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 254 205 165<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;140&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;140 Km.&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 254 172 105<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;175&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;175 Km.&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 254 136 40<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;210&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;210 Km.&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 234 105 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>END<span style=3D'mso-spacerun:yes'>=A0=A0=A0 =
</span><o:p></o:p></span></font></p>
color=3Dnavy
color:navy;mso-ansi-language:EN-US'><o:p>&nbsp;</o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>NAME &quot;Buffers&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>STATUS DEFAULT <o:p></o:p></span></font></p>
color=3Dnavy
</span>DATA &quot;/home/mapserv/data/galicia/bufers.shp&quot;<span
color=3Dnavy
color=3Dnavy
</span>CLASSITEM &quot;color&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0 </span><span
style=3D'mso-spacerun:yes'>=A0=A0=A0</span>NAME &quot;L=EDmites =
font-family:Arial;color:navy;mso-ansi-language:EN-US'>Galicia</span></fon=
font-family:Arial;color:navy;mso-ansi-language:EN-US'>&quot;<o:p></o:p></=
span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;1&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 204 204 153<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;2&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 214 213 165<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;3&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 215 215 181<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;4&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 222 222 188<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;5&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 230 230 206<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;6&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 238 238 214<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;7&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 239 241 230<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0</span>EXPRESSION =
&quot;8&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 247 247 239<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;9&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 102 204 255<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;10&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 115 212 255<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;11&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 140 215 254<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span><span
style=3D'mso-spacerun:yes'>=A0</span>EXPRESSION =
&quot;12&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 156 222 254<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;13&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 181 230 255<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;14&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 197 238 255<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION &quot;15&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 218 240 254<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
&quot;16&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 238 247 254<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>NAME &quot;sql&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>STATUS DEFAULT<o:p></o:p></span></font></p>
color=3Dnavy
</span>DATA &quot;the_geom from (select geo_talleres.oid,
geo_talleres.the_geom, taller_auditoria.cod_taller,
taller_auditoria.empleados_fijos, taller_auditoria.provincia,
taller_auditoria.localidad, taller_auditoria.id_fabrica, case when
empleados_fijos &gt;=3D'0' and empleados_fijos &lt;=3D'15' then '1' when
empleados_fijos &gt;'15' and empleados_fijos &lt;=3D'30' then '2' when
empleados_fijos &gt;'30' and empleados_fijos &lt;=3D'50' then '3' when
empleados_fijos &gt;'50' then '4' end as total from geo_talleres inner =
join
taller_auditoria on =
query&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>TYPE POINT<o:p></o:p></span></font></p>
color=3Dnavy
</span>CLASSITEM &quot;total&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>EXPRESSION ([total] =3D 5)<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;Empleados Fijos&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>END<span style=3D'mso-spacerun:yes'>=A0=A0 =
color=3Dnavy
color=3Dnavy
</span>EXPRESSION ([total] =3D 1)<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;Menos de 15&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>TEMPLATE &quot; &quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>COLOR 255 0 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>SYMBOL &quot;circle&quot;<o:p></o:p></span></font></p>
color=3Dnavy
</span>SIZE 8<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION ([total] =3D 2 )<o:p></o:p></span></font></p>
color=3Dnavy
</span>NAME &quot;16 - 30&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>COLOR 255 255 0<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0</span>EXPRESSION ([total] &lt;=3D 3 =
color=3Dnavy
</span>NAME &quot;31 - 50&quot;<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
</span>COLOR 0 0 255<o:p></o:p></span></font></p>
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>EXPRESSION ([total] =3D 4)<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span></span></font><font
color:navy'>NAME &quot;M=E1s de 51&quot;<o:p></o:p></span></font></p>
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>TEMPLATE &quot; =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span>COLOR 0 255 =
color=3Dnavy
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0 </span></span></font><font =
color:navy;mso-ansi-language:EN-US'>OUTLINECOLOR 0 0 =
color=3Dnavy
color=3Dnavy
color=3Dnavy
color=3Dnavy
</span>END
color=3Dnavy
color:navy;mso-ansi-language:EN-US'>#Fin<o:p></o:p></span></font></p>
color=3Dnavy
color:navy;mso-ansi-language:EN-US'>END<o:p></o:p></span></font></p>
face=3DArial><span
lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Arial;mso-ansi-language:EN-US'><o:p=
<p class=3DMsoPlainText style=3D'margin-left:35.4pt'><font size=3D2 =
face=3D"Courier New"><span
style=3D'font-size:10.0pt;mso-no-proof:yes'>Wilman =
Rojas.<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;mso-no-proof:yes'>Jefe Investigaci=F3n y =
Desarrollo.<o:p></o:p></span></font></p>
lang=3DEN-US =
style=3D'font-size:10.0pt;mso-ansi-language:EN-US;mso-no-proof:yes'>Geowe=
b
S.A <o:p></o:p></span></font></p>
lang=3DEN-US =
style=3D'font-size:10.0pt;mso-ansi-language:EN-US;mso-no-proof:yes'>www.g=
eoweb.com.co<o:p></o:p></span></font></p>
</div>
</body>
</html>
--Boundary_(ID_83TVniVDsB8mxQnvfPhdjw)--
