[Mapserver-users] Layers hidden.
Sebastian Albrecht api at justapi.de
Tue Dec 2 03:44:17 EST 2003
I suppose your problem is nothing is displayed by Mapserver.
You should add PROJECTION parameters to your mapfile and to each
layer. Try using a GRID layer to simply see in which extent off the
map you are.
Sebastian
