[Mapserver-users] Is it mandatory to use projection?
Chip Hankley
Chip.Hankley at rmtinc.com
Tue Dec 9 11:12:12 EST 2003
Rémi,
Specifying a projection in MapServer is NOT mandatory. The only time you need to do this is when you are combining data sets from a variety of projections, or you want to show the data in a different projection (perhaps your data is geographic, and you want to display it in albers).
The "default" projection is the projection of your data... basically as long as all of your layers use the same projection. It IS important, however, to make sure you specify the correct UNITS in your mapfile, as this directly affects the SCALE settings in MapServer.
Chip
Outgoing messages, along with any attachments, are scanned for viruses at RMT prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient. Any review or distribution
by others is strictly prohibited. If you are not the intended recipient,
please contact the sender immediately and delete all copies.
