[Mapserver-users] Is it mandatory to use projection?
Tyler Mitchell TMitchell at lignum.com
Tue Dec 9 13:37:36 EST 2003
It is also important to make sure that when you set EXTENT that you use the
same units that your data is in.
             "Chip Hankley"
             <Chip.Hankley at rmt
             inc.com>                                                   To
             Sent by:                  <remi.baud at eivd.ch>,
             mapserver-users-a         <mapserver-users at lists.gis.umn.edu>
             dmin at lists.gis.um                                          cc
             n.edu
        Fax to
             12/09/2003 08:12                                      Subject
             AM                        Re: [Mapserver-users] Is it
Rémi,
Specifying a projection in MapServer is NOT mandatory. The only time you
need to do this is when you are combining data sets from a variety of
projections, or you want to show the data in a different projection
(perhaps your data is geographic, and you want to display it in albers).
The "default" projection is the projection of your data... basically as
long as all of your layers use the same projection. It IS important,
however, to make sure you specify the correct UNITS in your mapfile, as
this directly affects the SCALE settings in MapServer.
Chip
Outgoing messages, along with any attachments, are scanned for viruses at
RMT prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient.  Any review or distribution
by others is strictly prohibited.  If you are not the intended recipient,
please contact the sender immediately and delete all copies.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
