[Mapserver-users] Complications in using mapinfo tables in mapserver
Chiang Zeliang
chiang_8_3 at hotmail.com
Tue Dec 9 22:30:27 EST 2003
I checked the projection and units a couple of times but it is in the
correct projection and units. A moment ago, I deleted off the other layers
and used only the 'Mainroads' layer but the layer does not appear? It does
not state any existing errors or problems, why is that so?
From,
Chiang
>From: Michael Roach <burntmage at yahoo.com>
>To: Mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] Complications in using mapinfo tables in
>mapserver
>Date: Tue, 9 Dec 2003 11:09:45 -0800 (PST)
> I would try to double check the projection and units of the road and
>cities .TAB files. See if they would fall in with the country and inland
>waters map data. Also I would try to bring up the roads and cities in a
>different map file to test. Just to see what happens.
>I have gotten in the habit of making all my maps the same projection before
>I load them. Simply because some people like making up there own
>projections.
_________________________________________________________________
Are you in love? Find a date on MSN Personals http://match.msn.com.my/
