[Mapserver-users] Re: Question about MapInfo.
Daniel Morissette morissette at dmsolutions.ca
Mon Dec 15 10:29:56 EST 2003
Denis Louvegnies wrote:
> Hello Daniel,
> Do you know if I should be able to open MapInfo document if I use the
> pre-compile version of php_mapscript4.1.dll ?
> Thank very much,
It depends whether the build you got includes OGR or not, you can find
out by running the following PHP script:
<?php
   dl("php_mapscript_41.dll");
   phpinfo();
Look for the PHP MapScript version information in the phpinfo output. If
it contains INPUT=OGR then the answer is yes you should be able to open
MapInfo files.
Daniel
P.S. Use the mapserver-users list for your questions. I have CC'd this
reply to the list.
  DM Solutions Group              http://www.dmsolutions.ca/
