[Mapserver-users] Empty screen with .tab file?
Denis Louvegnies denis at louvegnies.com
Tue Dec 16 15:57:33 EST 2003
Hi Daniel,
Hugo and I have the same problem.
For me even with the absolute path it still doesn't work.
I wounder if any one could open a MapInfo file with php_mapscript41.dll....
Denis
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, December 16, 2003 9:10 PM
Subject: Re: [Mapserver-users] Empty screen with .tab file?
> Hugo Nathaniel Rodrigues wrote:
> > i see the END, then i tried that one you sended to me, and i get this
> > errors:
> > Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'test'.
> > in c:\arquivos de programas\apache group\apache\htdocs\testes
> > basicos\mapabasico.phtml on line 8
> > Warning: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
connection
> > `./distrito.tab'. File not found or unsupported format. in c:\arquivos
de
> > programas\apache group\apache\htdocs\testes basicos\mapabasico.phtml on
line
> > 8
> Have you tried setting an absolute path for the connection string?
> e.g.
> LAYER
>     NAME test
>     TYPE POLYGON
>     STATUS DEFAULT
>     CONNECTIONTYPE OGR
>     CONNECTION "/path/to/data/distrito.tab"
>     CLASS
>     END
> END
> Daniel
>   Daniel Morissette               morissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
