[Mapserver-users] Locating and centering on a point
Palle Due Larsen palle at mail-online.dk
Mon Dec 22 09:03:17 EST 2003
Build a select box showing the names of the restaurants with the
shapeindexes as values, like this:
<option value="21">Ristorante Napoli</option>
Then use indexquery mode with the shapeindex parameter set to the value
and the qlayer set to your restaurant layer. You can set the buffer
parameter as well, so that you don't zoom to close to the point.
If you have some server-side software, such as perl or php you can
generate the select box automatically.
Best regards & a Merry Christmas
Palle Due Larsen
Carl Bro GIS&IT
-----Original Message-----
To: <mapserver-users at lists.gis.umn.edu>
Date: Mon, 22 Dec 2003 11:05:55 +0100
Subject: [Mapserver-users] Locating and centering on a point
> Hi,
> I'd like to center my map on a precise point object. The user choose
> from a
> list of objects (dropdown list box), like restaurants, and the map is
> centered on the restaurant
> choosen.
> What is the best way to do this?
> I look at the "province selection" in gmap example, but I don't want
> to
> preload all the coordinates in the html. I prefer a solution where
> coordinates are read from
> the shape file or using a postgis database.
> Leandro
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Få en gratis emailkonto her: www.mail-online.dk
Deltag i en lille konkurrence på nettet, og
vind et gavekort på 50.000 kroner...
KLIK HER: www.nyhedsbasen.dk/konkurrence
