[Mapserver-users] about shapefile
Sean Gillies sgillies at frii.com
Tue Dec 23 11:32:39 EST 2003
On Tuesday, December 23, 2003, at 08:54  AM, Aga Shirazi wrote:
> Hi,
> I wanted to learn how a shpefile is structured, created and compiled.
> I read the technical description from ESRI about Shapefiles, but I
> couldnt get much out of it as I lack a GIS programming background. For
> instance: I have no idea what PolygonZ or M is, and why would I use
> it. I also couldnt find in the Tech. paper how can I code and compile
> a shapefile?
> I would be greatly appreciative if someone could name some websites or
> books that could guide me.
> Thanks
> Aga Shirazi
How can you create a shapefile?  My favorite is to use Frank Warmerdam's
shapelib, a library for reading and writing shapefile features and
attributes
http://shapelib.maptools.org/
with Python bindings: http://www.hobu.biz/software/shapelib.  Shapelib
is all you need for creating shapefiles for use with MapServer.
Frank Warmerdam's OGR library
http://ogr.maptools.org/
also provides a C/C++ API for shapefiles and has Python bindings.
Shapelib has been assimilated into MapServer and you can also read and
write shapefiles using the shapefileObj class of MapScript,
If you are a Java user, there is sf4java (used in deegree, JUMP(?),
and other open-source Java GIS).
Don't trouble yourself too much with the shapefile specs, jump right in
with one of these programming interfaces.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
