[Mapserver-users] Geotiff and Extent confusion
Michael Hughes
mike at probass.com
Wed Dec 24 14:56:37 EST 2003
I hate posting this because I see the same question posted again and
again in the list. Unfortunately there are no real answers on the list
or the wiki, so here it goes again.
I have installed mapserver 4.01 and verified that it works via the
demo. I have downloaded a USGS GeoTiff file from topozone and the
associated tfw file. I adjusted my map file to attempt to load the tif
file instead of the pngs created for the demo. Of course I cannot get
the darned thing to display. I am sure that the problem lies in the
extent settings. I am just not smart enought to fix it yet. The values
provided by gdalinfo do not match the values provided in the tfw file
just to add to my confusion. I am trying to simply display the image
with the mapping server, without adding overlays or anything else at
this point. I am sure that it is simply a newbie mistake that is
keeping me from displaying the image successfully, hopefully someone can
help me out. I have provided all of the information that I think is
applicable below.
Michael Hughes
./mapserv -v
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=TIFF
INPUT=EPPL7 INPUT=JPEG INPUT=GDAL INPUT=SHAPEFILE
cat o34084b1.wld
2.438400000000
0.000000000000
0.000000000000
-2.438400000000
763785.222415230000
3794653.234146172600
/usr/local/bin/gdalinfo o34084b1.tif
Driver: GTiff/GeoTIFF
Size is 5717, 6933
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 6933.0)
Upper Right ( 5717.0, 0.0)
Lower Right ( 5717.0, 6933.0)
Center ( 2858.5, 3466.5)
Band 1 Block=5717x6933 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 0,0,0,255
1: 255,255,255,255
2: 0,151,164,255
<...snip...>
cat o34084b1.map
NAME BufordDam
SIZE 600 600
EXTENT 763785.22241523 3794653.23414617 777725.55521523 3777747.80694617
SHAPEPATH "/var/www/html/maps/"
DEBUG on
WEB
LOG "/tmp/buforddam.log"
HEADER BufordDam_header.html
TEMPLATE BufordDam.html
FOOTER BufordDam_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "/var/www/html/maps/images/"
IMAGEURL "/maps/images/"
END
LAYER
NAME "BufordDam"
DATA o34084b1.tif
TYPE raster
STATUS DEFAULT
END #END OF LAYER
END # Map File
