[Mapserver-users] Geotiff and Extent confusion
Dylan Keon keon at nacse.org
Wed Dec 24 15:26:58 EST 2003
 From your mapserv -v I see you have both GDAL and MapServer's TIFF
support enabled.  If you compile --with-gdal it's also a good idea to
compile --without-tiff.
Also, is your EXTENT correct?  It should be in the form of 'minx miny
maxx maxy'.  I think you might have the miny and maxy switched.
--Dylan
On 12/24/2003 11:56 AM Michael Hughes wrote:
> I hate posting this because I see the same question posted again and
> again in the list.  Unfortunately there are no real answers on the list
> or the wiki, so here it goes again.
> I have installed mapserver 4.01 and verified that it works via the
> demo.  I have downloaded a USGS GeoTiff file from topozone and the
> associated tfw file.  I adjusted my map file to attempt to load the tif
> file instead of the pngs created for the demo.  Of course I cannot get
> the darned thing to display.  I am sure that the problem lies in the
> extent settings.  I am just not smart enought to fix it yet.  The values
> provided by gdalinfo do not match the values provided in the tfw file
> just to add to my confusion.  I am trying to simply display the image
> with the mapping server, without adding overlays or anything else at
> this point.  I am sure that it is simply a newbie mistake that is
> keeping me from displaying the image successfully, hopefully someone can
> help me out.  I have provided all of the information that I think is
> applicable below.
> Michael Hughes
> ./mapserv -v
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=TIFF
> INPUT=EPPL7 INPUT=JPEG INPUT=GDAL INPUT=SHAPEFILE
> cat  o34084b1.wld
> 2.438400000000
> 0.000000000000
> 0.000000000000
> -2.438400000000
> 763785.222415230000
> 3794653.234146172600
> /usr/local/bin/gdalinfo o34084b1.tif
> Driver: GTiff/GeoTIFF
> Size is 5717, 6933
> Coordinate System is `'
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0, 6933.0)
> Upper Right ( 5717.0,    0.0)
> Lower Right ( 5717.0, 6933.0)
> Center      ( 2858.5, 3466.5)
> Band 1 Block=5717x6933 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
>   0: 0,0,0,255
>   1: 255,255,255,255
>   2: 0,151,164,255
> <...snip...>
> cat o34084b1.map
> NAME  BufordDam
> SIZE 600 600
> EXTENT 763785.22241523 3794653.23414617 777725.55521523 3777747.80694617
> SHAPEPATH "/var/www/html/maps/"
> DEBUG on
> WEB
> LOG "/tmp/buforddam.log"
> HEADER BufordDam_header.html
> TEMPLATE BufordDam.html
> FOOTER BufordDam_footer.html
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "/var/www/html/maps/images/"
> IMAGEURL "/maps/images/"
> END
> LAYER
> NAME "BufordDam"
> DATA o34084b1.tif
> TYPE raster
> STATUS DEFAULT
> END #END OF LAYER
> END # Map File
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
