[Mapserver-users] Geotiff and Extent confusion
Michael Hughes mike at probass.com
Wed Dec 24 17:57:04 EST 2003
Thanks a million.  The format of the Extent line was incorrect at you
noted.  I also recompiled the mapserv and it works now.  After 2 days of
banging my head against the wall I finally am moving forward again.
Michael Hughes
Dylan Keon wrote:
> From your mapserv -v I see you have both GDAL and MapServer's TIFF
> support enabled.  If you compile --with-gdal it's also a good idea to
> compile --without-tiff.
> Also, is your EXTENT correct?  It should be in the form of 'minx miny
> maxx maxy'.  I think you might have the miny and maxy switched.
> --Dylan
> On 12/24/2003 11:56 AM Michael Hughes wrote:
>> I hate posting this because I see the same question posted again and
>> again in the list.  Unfortunately there are no real answers on the
>> list or the wiki, so here it goes again.
>> I have installed mapserver 4.01 and verified that it works via the
>> demo.  I have downloaded a USGS GeoTiff file from topozone and the
>> associated tfw file.  I adjusted my map file to attempt to load the
>> tif file instead of the pngs created for the demo.  Of course I
>> cannot get the darned thing to display.  I am sure that the problem
>> lies in the extent settings.  I am just not smart enought to fix it
>> yet.  The values provided by gdalinfo do not match the values
>> provided in the tfw file just to add to my confusion.  I am trying to
>> simply display the image with the mapping server, without adding
>> overlays or anything else at this point.  I am sure that it is simply
>> a newbie mistake that is keeping me from displaying the image
>> successfully, hopefully someone can help me out.  I have provided all
>> of the information that I think is applicable below.
>> Michael Hughes
