[Mapserver-users] data layer buffer size
Steve Lime steve.lime at dnr.state.mn.us
Mon Dec 29 11:26:51 EST 2003
There is no default length built in, the data member is a char *. Only
thing I can think of is that flex (which is used to tokenize the
mapfile) may have a setting that can be changed. A cursory google search
suggests that flex tokens can be upto 8k in length. Are you approaching
that?
Steve
>>> Nick Petersen-Bergeron <bergeron at zedxinc.com> 12/29/2003 9:28:27 AM
I'm wondering if there's a maximum length for the data member of a
layer?  If so, how do I increase that?  I'm having a problem with long
queries using PostGIS with Perl mapscript.  I can use a SetFilter to
get
around the problem, but I'd like to get to the root of it instead of
using
a workaround.
Thanks,
Developer
ZedX Inc.
369 Rolling Ridge Drive
Bellefonte, PA. 16823
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
