[Mapserver-users] [XML] Proposal for a MapScript XML Data Model Project and Discussion
Gerry Creager N5JXS gerry.creager at tamu.edu
Mon Dec 29 22:59:39 EST 2003
Makes more sense from that perspective.  However, the mapfile format has
the beginnings of one.  Creating such a schema isn't a trivial project,
but should be enhanced from some of the use-case tools now available.
TTFN, Gerry
Sean Gillies wrote:
> Gerry,
> GML is for data, feature topology, stuff like that.  Maybe I wasn't
> as clear as I thought :(
> What I'm interested in is an XML standard for map/layer/class
> configuration.  The _application_ rather than the data.  Think
> of a WMS capabilities type of document, not GML.
> cheers,
> Sean
> On Monday, December 29, 2003, at 08:24  PM, Gerry Creager N5JXS wrote:
>> Er... GML?
>> Sean Gillies wrote:
>>> Greetings,
>>> One of the things that I would most like to see in 2004 is more serious
>>> discussion about the future of an XML map configuration format for
>>> MapServer.  To this end, I've written up a proposal on the MapServer
>>> Wiki.  Will you please read it and consider joining in the discussion?
>> Gerry Creager -- gerry.creager at tamu.edu
>> Network Engineering -- AATLT, Texas A&M University
>> Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
>> Page: 979.228.0173
>> Office: 903A Eller Bldg, TAMU, College Station, TX 77843
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
Page: 979.228.0173
