[Mapserver-users] help with python mapscript (no image)
Christoph Spoerri spoerri at duke.edu
Tue Dec 30 11:55:44 EST 2003
Hi there,
After using the php mapscripts for over a year now, I started to look into the
python mapscripts. It seems to provide more functionality and doesn't have to
have to be run as cgi (I'm using mod_python).
The compilation, installation and setup went pretty smoothly. Now, I would
like to create my first map, but for some reason I do not get an image in my
output directory. I can create an image of the map by saving the image
(imgObj::saveImage() ), but the mapObje::draw() doesn't seem to work.
I run also the following from the python prompt:
>>> from mapscript import *
>>> myMap = mapObj('/var/www/htdocs/mapserver/obis_test/testing.map')
>>> mapImg = myMap.draw()
>>> mapImg.imageurl
'/output/'
>>> mapImg.save('/tmp/test.png')
As you can see the imageurl only points to the directory where the image
should be and doesn't include the image name.
I spent the last 4 hours search the mailing list, google, etc, yet wasn't able
to find a solution. Any ideas? I have attached my map file.
thanks, and a happy new year
Christoph
************** my map file ************************
MAP
	NAME PYDEMO
	EXTENT -180 -90 180 90
	SIZE 400 300
	SHAPEPATH "/usr/local/ims_data/"
	UNITS DD
	RESOLUTION 72
	IMAGETYPE PNG24
	IMAGECOLOR 245 245 245
	WEB
		IMAGEPATH "/var/www/htdocs/ims_output/"
		IMAGEURL "/output/"
	END
	LAYER
		NAME "Background"
		STATUS DEFAULT
		DATA "datalib/global/ocean_log.tif"
		TYPE RASTER
		OFFSITE 0 0 0
	END
	LAYER
		NAME "Continents"
		STATUS DEFAULT
		DATA "datalib/global/world_usa_canada"
		TYPE POLYGON
		TRANSPARENCY 0
		CLASS
			COLOR 180 210 170
			OUTLINECOLOR 150 190 140
		END
	END
END
