[Mapserver-users] Mapserver 3.6.4 and RedHat 8.0
Klaus Zahradnik klaus.zahradnik at sysinet.com
Mon Feb 3 16:52:16 EST 2003
Oh, cool!thanks that worked.
I honestely did not see that thread!
Thanks again!
> -----Ursprüngliche Nachricht-----
> Von: Dana Quinn <dana at nextbus.com>
> Gesendet: Monday, 03. February 2003 20:00
> An: Klaus Zahradnik <klaus.zahradnik at sysinet.com>
> Betreff: Re: [Mapserver-users] Mapserver 3.6.4 and RedHat 8.0
> Klaus Zahradnik wrote:
> > Hy-
> > To make it short, here is the link with the message I get:
> > http://lists.gis.umn.edu/pipermail/mapserver-users/2002-December/000378.html
> > It already has been posted, but there was no answere (at least google makes it look like that ;o) )
> > berst regagrds
> > Klaus
> Klaus-
> 	I think you\\'re in luck with this problem.  If you can provide
> the right search strings to the search engine for the mailing list
> search engine, you can find some discussion on this error message.
> I think this post is the most succint at how to fix the problem:
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0212/msg00337.html
> I was able to follow that advice and get everything working.  This
> is specifically what I did (this is directly from that post):
> Or try  editing your Makefile and add "-lstdc++" as shown below
>                   STATIC_LIBS= $(GD_STATIC) $(OGR_STATIC) -lstdc++
> 	You\\'ll need to do something similar if you use Perl/Mapscript.
> There was some discussion of that issue on the mailing list, and
> there is a small section in the wiki about Perl Mapscript and RH 8.0.
> dana
> Dana Quinn, dana at nextbus.com
> NextBus Information Systems
> (510) 420-3117
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Klaus Zahradnik
Systemadministrator
iNet Internet Plattform
Neudoerflerstrasse 2
A - 2700 Wiener Neustadt
Tel.: ++43 (0)2622 / 24480 13
Fax.: ++43 (0)2622 / 24480 20
WWW: http://www.sysinet.com
eMail: klaus.zahradnik at sysinet.com
