[Mapserver-users] How to make labels in MS with PostGIS
Lowther, David W
dlowther at ou.edu
Tue Feb 4 09:33:10 EST 2003
Christian,
You've got to get everything you need (geometry and attributes) into that
data statement. I am using something that looks like this:
DATA "the_geom from (select oid,* from table) as foo"
HTH,
Dave
> -----Original Message-----
> From: christian.schuster at rsag.ch [mailto:christian.schuster at rsag.ch]
> Sent: Monday, February 03, 2003 11:03 PM
> To: Paul Ramsey
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] How to make labels in MS with PostGIS
> Hi Paul,
> Sorry that I am coming back to you after few days. I am still
> not able to make labels. I am a newbie and I think it is a
> generall understanding problem of how the map file works.
> Below you see my layer definitions for the labels. There I
> have a big question about it. So I have a table called
> 'geo3'. In this table I have a column as identifier which is
> called 'ID'. Then the second column is of type varcahr(20 and
> called 'NAME'. The last one is the geometry column. Now I can
> draw the map and all. Just the labels are not working. I am
> not sure what the tag 'DATA' has to look like. The way it is
> now, I just get back the geometry column. But what I would
> like is to have the column 'NAME' to use for labeling. If I
> change the tag 'DATA' to "NAME from geo3" then I would have
> this. But I do not know how MapServer knows where to draw the
> labels. If I change the tag 'DATA' to "* from geo" then I get
> an error. So I am quite confused. I also tried so many times
> already. if someone could solve my confusion would be really nice.
> LAYER
> NAME "labels"
> ### Connect to a remote spatial database
> CONNECTIONTYPE postgis
> CONNECTION "user=*** dbname=myGISdb host=127.0.0.1 port=5432"
> ### Get the labels from the table
> DATA "geom from geo3"
> STATUS ON
> TYPE ANNOTATION
> LABELITEM "name"
> CLASS
> EXPRESSION 'name'
> COLOR -1 -1 -1
> LABEL
> COLOR 0 0 0
> TYPE BITMAP
> SIZE MEDIUM
> POSITION CC
> PARTIALS FALSE
> BUFFER 2
> END # end of label
> END
> END
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
> Paul Ramsey
> <pramsey at refracti
> ons.net>
> To
> 31.01.2003 17:18
> cc
> Subject
> How to make
> labels in MS with
> PostGIS
> Same as with any other data source. Declare a labelitem and
> add a label object to your class object. Should be examples
> in the map file reference page. The only potential gotcha is
> that your labelitem attribute should be given in lower case.
> christian.schuster at rsag.ch wrote:
> > Hi list,
> > I have a table 'geo' with a geometry column, a column 'name' as
> > varchar(20) and an ID column as the Primary Key. Is it
> possible to use
> > the text in the column 'name' as the label text and if so what does
> > the layer look like in the map file.
> > Thanaks for helping
> > Christian Schuster
> > Rudolf Schuster AG
> > Postfach 277
> > CH - 3000 Bern 11
> > http://www.rsag.ch
> > ++41 31 348 05 30
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
