[Mapserver-users] Mapserver 3.7, PHP/mapscript, Apache 2.x, RH8
Jan Hartmann jhart at frw.uva.nl
Wed Feb 5 12:22:40 EST 2003
I had no problem at all compiling and running MapServer CGI and
MapScript PHP for Apache 2.0 on Linux. Got the impression that compiling
Apache with mpm=worker ran faster than the default mpm=prefork, but I
did no systematic testing.
Jan Hartmann
Vincent Schut wrote:
> Steve,
>>Hi all,
>>I plan to try and build Mapserver 3.7, PHP/Mapscript on RH 8.0 which comes
>>with Apache 2.0. I saw todays posts about MS 3.6.4 and RH 8.0.
>>Questions,
>>Has anyone built this already?
> not exactly, but I thought you'd still might be interested.
> I just did a rebuild of everything but I'm still using apache 1.3.23.
> For the others, I used the latest versions: proj, gdal-cvs, mapserver-cvs, gd
> 2.0.11, php 4.3.0., ming 0.2a (as ming-cvs gives errors when making the
> php_ming module which I also like to use).
> I compiled both a php module to use for normal php applications, and a cgi
> which should be as clean as possible, to use with mapserver apps.
> Mapserver was compiled with quite a bunch of options, including the php module
> which seems to work ok.
> I've just started testing, simple things seem to work ok.
> I'm sorry I can't help you on the apache 2.0 things, but I hope this gives you
> some confidence about the rest :-)
> If you like, I can send you my ./configure script options for
> mapserver/php/etc.
> don't hesitate to ask more specific questions if you have them, I'll be glad
> to share my experiences ( it took me quite some trial&error time to get all
> config options right...).
> Regards,
> Vincent Schut.
>>Any clues as to how to configure Apache 2.0 and PHP 4.3 as CGI, it seems
>>the httpd.conf file is significantly different.
>>Plan to build with:
>>  GDAL lastest CVS
>>  GD 2.x
>>  Freetype 2.x
>>  basically the lastest of all the libs
>>Any help or hints would be appreaciated.
>>I'll report back whatever I find out.
>>-Steve W.
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
