[Mapserver-users] WMS Woes
Hankley, Chip Chip.Hankley at GASAI.Com
Thu Feb 6 15:59:01 EST 2003
I switched up to a 3.7dev MapServer executable:
MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=GD2_RGB INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
While this took care of the client hanging, I'm still not getting a map
(image) returned from the WMS Server.
I've simplified the mapfiles so that:
a) the WMS server map file has only ONE layer
b) the WMS client map file has only ONE local layer in addition to ONE WMS
Layer
c) EVERYTHING is in the same projection (UTM16 N)
I have put the same information as before (updated) at
http://207.250.243.23/WMS/WMSWoes.html
  Here you will find:
    WMS Server mapfile
    WMS Client mapfile
    XML output of GETCAPABILITIES
I am still somewhat confused by the "wms_onlineresource" syntax on the
server - is it supposed to end with a "&"?
And, the CONNECTION line on the client:
  is it LAYER=xxx or LAYERS=xxx?
TIA!
Chip
> -----Original Message-----
> From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
> Sent: Thursday, February 06, 2003 12:10 PM
> To: Hankley, Chip
> Cc: MapServer List (E-mail)
> Subject: Re: [Mapserver-users] WMS Woes
> "Hankley, Chip" wrote:
> > I'm attempting to set up my first WMS server / client, and
> am running into a
> > problem: when I try to connect to the WMS Server using a
> MapServer based WMS
> > Client, the MapServer just hangs (on the WMS Client end). I
> never receive an
> > error, but process just terminates with a standard "IIS
> Timeout" type
> > statement.
> First thing to try would be to upgrade your WMS server to version
> 3.6.4.  A bad memory corruption bug with the SRS parameter in the WMS
> interface was fixed between 3.6.3 and 3.6.4, and I think the symptoms
> were an infinite loop like this on Windows.
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
