[Mapserver-users] .tiff resolution
Charlton Purvis
cpurvis at asgnet.psc.sc.edu
Thu Feb 6 16:00:38 EST 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C2CE22.CD2DE41A
Content-Type: text/plain;
charset="US-Ascii"
Content-Transfer-Encoding: quoted-printable
I'd like a 72dpi .tiff to be displayed as accurately in MapServer as it
is Photoshop. This .tiff is a product of ArcMap. I took a .shp and
exported it to a map (.tiff, 72dpi). Before I did this I set the
extents manually. I used these extents to fill in my MapServer extents.
A .wld was also a product of the ArcMap .tiff translation. So I carried
that over to my data directory along w/ the .tiff.
=20
So I've ended up w/ a .tiff and a .wld, but I must be missing something
since it really doesn't look as clean from w/i MapServer as I think a
72dpi image should. What can I adjust?
=20
The MapServer width and height are in proportion to the extents, and I'm
working exclusively under MapLab. I haven't hardcoded anything under
the min/max scale (mostly because I don't have a firm grasp on what that
is actually doing).
=20
Any help would greatly be appreciated.
=20
=20
=20
=20
Charlton Purvis
(803) 777-4453 : voice
(803) 777-8833 : fax
cpurvis at sc.edu
=20
Advanced Solutions Group
Department of Physics and Astronomy
University of South Carolina
Columbia, SC 29208
=20
Content-Type: text/html;
charset="US-Ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C2CDF8.E445AC30">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"PostalCode"/>
<o:SmartTagType =
name=3D"State"/>
<o:SmartTagType =
name=3D"City"/>
<o:SmartTagType =
name=3D"PlaceName"/>
<o:SmartTagType =
name=3D"PlaceType"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:DrawingGridHorizontalSpacing>6 pt</w:DrawingGridHorizontalSpacing>
<w:DisplayHorizontalDrawingGridEvery>2</w:DisplayHorizontalDrawingGridEve=
ry>
<w:DisplayVerticalDrawingGridEvery>2</w:DisplayVerticalDrawingGridEvery>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:Arial;
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt'>I’d
like a 72dpi .tiff to be displayed as accurately in MapServer as it is
Photoshop.<span style=3D'mso-spacerun:yes'> </span>This .tiff is a =
product
of ArcMap.<span style=3D'mso-spacerun:yes'> </span>I took a .shp =
and exported
it to a map (.tiff, 72dpi).<span style=3D'mso-spacerun:yes'> =
</span>Before
I did this I set the extents manually.<span =
</span>I used these extents to fill in my MapServer extents.<span
style=3D'mso-spacerun:yes'> </span>A .wld was also a product of =
the ArcMap .tiff
translation.<span style=3D'mso-spacerun:yes'> </span>So I carried =
that over
to my data directory along w/ the .tiff.<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt'><o:p> </o:p></span></font></p>
style=3D'font-size:10.0pt'>So I’ve
ended up w/ a .tiff and a .wld, but I must be missing something since it =
really
doesn’t look as clean from w/i MapServer as I think a 72dpi image =
should.<span
style=3D'mso-spacerun:yes'> </span>What can I =
adjust?<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt'>The MapServer
width and height are in proportion to the extents, and I’m working
exclusively under MapLab.<span style=3D'mso-spacerun:yes'> =
</span>I haven’t
hardcoded anything under the min/max scale (mostly because I don’t =
have a
firm grasp on what that is actually doing).<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt'>Any
help would greatly be appreciated.<o:p></o:p></span></font></p>
style=3D'font-size:10.0pt;
mso-no-proof:yes'> <o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D1 face=3DArial><span =
style=3D'font-size:7.5pt;
mso-no-proof:yes'>Charlton Purvis</span></font><span =
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
mso-no-proof:yes'>(803) 777-4453 : voice</span></font><span =
mso-no-proof:yes'>(803) 777-8833 : fax</span></font><span =
mso-no-proof:yes'><a =
href=3D"mailto:cpurvis at sc.edu">cpurvis at sc.edu</a></span></font><span
mso-no-proof:yes'>Advanced Solutions Group<br>
Department of Physics and Astronomy<br>
</span></font><st1:place><st1:PlaceType><font size=3D1><span =
style=3D'font-size:
7.5pt;mso-no-proof:yes'>University</span></font></st1:PlaceType><font =
size=3D1><span
style=3D'font-size:7.5pt;mso-no-proof:yes'> of =
</span></font><st1:PlaceName><font
size=3D1><span style=3D'font-size:7.5pt;mso-no-proof:yes'>South =
Carolina</span></font></st1:PlaceName></st1:place><font
size=3D1><span style=3D'font-size:7.5pt;mso-no-proof:yes'><br>
</span></font><st1:place><st1:City><font size=3D1><span =
mso-no-proof:yes'>Columbia</span></font></st1:City><font =
size=3D1><span
style=3D'font-size:7.5pt;mso-no-proof:yes'>, =
</span></font><st1:State><font
size=3D1><span =
style=3D'font-size:7.5pt;mso-no-proof:yes'>SC</span></font></st1:State><f=
ont
size=3D1><span style=3D'font-size:7.5pt;mso-no-proof:yes'> =
</span></font><st1:PostalCode><font
size=3D1><span =
style=3D'font-size:7.5pt;mso-no-proof:yes'>29208</span></font></st1:Posta=
lCode></st1:place><o:p></o:p></p>
</div>
</body>
</html>
=00
------_=_NextPart_001_01C2CE22.CD2DE41A--
