[Mapserver-users] .tiff resolution
Charlton Purvis cpurvis at asgnet.psc.sc.edu
Fri Feb 7 13:29:37 EST 2003
Thanks, Chip:
Explaining the layout of the .wld was very helpful.  Your computations
were correct.  But I'm still not completely satisfied w/ my final
product.  I'm w/i the 8 bit limit, and converting the tif to gif under
Photoshop keeps the image the same.  So I'm not convinced that it's a
display problem or a gif limitation.
But maybe I should backup and ask you (and the list) if my approach is
off-base.  I've been playing w/ the Canada demo as well, and I noticed
that the actual width and height of the Canada tif is large.  My
resulting tif (from my data) is not.
My goal (right now) is to go from a dem to tif.  Let's fast-forward and
work w/ the fact that I can get the dem to a shapefile.  From that
point, all I want to do is to export the shapefile to a tif (w/ the .wld
being created as well).  Am I going around my rear end to get to my
elbow?  I'm sure.  But am I missing something critical to preserving the
quality of the data when I go from the shapefile to the tif (ArcMap)?
Thanks again,
Charlton
-----Original Message-----
From: Hankley, Chip [mailto:Chip.Hankley at GASAI.Com]
Sent: Friday, February 07, 2003 11:41 AM
To: Charlton Purvis; MapServer List (E-mail)
Subject: RE: [Mapserver-users] .tiff resolution
Charlton...
I'm getting different extents than you are. My calcs:
EXTENT 593226.92463 3623834.999945 605723.07543 3637755
Here's how I did it:
31.24	 - cell width
0.00	 - rotation
0.00	 - rotation
-31.28 - cell height
593226.92 - ULx (NOTE UL is Upper Left Corner)
3637755.00 - ULy
400.00 - Image Width (pixels)
445.00 - Image Height (pixels)
Top	      3637755.00  (ULy)
Bottom	3623835     (ULy + [cell height] * [image height])
Left	      593226.92   (ULx)
Right  	605723.0754 (ULx + [cell width] * [image width])
As far as image quality goes, make sure you're comparing apples to
apples.
Is the native image 8 bit (256 colors) or 24 bit? Also, if it's a TIFF,
you're output is likely either PNG, or GIF. This also will result in
some
differences.
Chip
