[Mapserver-users] .tiff resolution
Ed McNierney
ed at topozone.com
Fri Feb 7 14:50:41 EST 2003
Charlton -
If you have the data in a shapefile, you will get MUCH better output results by serving that data as a shapefile in MapServer than by converting it to a TIF and then serving the TIF. Both processes essentially do the same thing (generate a raster image) but MapServer can customize that image each time to the requested output resolution, whereas the TIF image is frozen at a particular resolution.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Charlton Purvis [mailto:cpurvis at asgnet.psc.sc.edu]
Sent: Friday, February 07, 2003 1:30 PM
To: Hankley, Chip; MapServer List (E-mail)
Subject: RE: [Mapserver-users] .tiff resolution
Thanks, Chip:
Explaining the layout of the .wld was very helpful. Your computations
were correct. But I'm still not completely satisfied w/ my final
product. I'm w/i the 8 bit limit, and converting the tif to gif under
Photoshop keeps the image the same. So I'm not convinced that it's a
display problem or a gif limitation.
But maybe I should backup and ask you (and the list) if my approach is
off-base. I've been playing w/ the Canada demo as well, and I noticed
that the actual width and height of the Canada tif is large. My
resulting tif (from my data) is not.
My goal (right now) is to go from a dem to tif. Let's fast-forward and
work w/ the fact that I can get the dem to a shapefile. From that
point, all I want to do is to export the shapefile to a tif (w/ the .wld
being created as well). Am I going around my rear end to get to my
elbow? I'm sure. But am I missing something critical to preserving the
quality of the data when I go from the shapefile to the tif (ArcMap)?
Thanks again,
Charlton
From: Hankley, Chip [mailto:Chip.Hankley at GASAI.Com]
Sent: Friday, February 07, 2003 11:41 AM
To: Charlton Purvis; MapServer List (E-mail)
Charlton...
I'm getting different extents than you are. My calcs:
EXTENT 593226.92463 3623834.999945 605723.07543 3637755
Here's how I did it:
31.24 - cell width
0.00 - rotation
0.00 - rotation
-31.28 - cell height
593226.92 - ULx (NOTE UL is Upper Left Corner)
3637755.00 - ULy
400.00 - Image Width (pixels)
445.00 - Image Height (pixels)
Top 3637755.00 (ULy)
Bottom 3623835 (ULy + [cell height] * [image height])
Left 593226.92 (ULx)
Right 605723.0754 (ULx + [cell width] * [image width])
As far as image quality goes, make sure you're comparing apples to
apples.
Is the native image 8 bit (256 colors) or 24 bit? Also, if it's a TIFF,
you're output is likely either PNG, or GIF. This also will result in
some
differences.
Chip
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
