[Mapserver-users] win32 postgis
Richard Greenwood rich at greenwoodmap.com
Sun Feb 9 21:52:44 EST 2003
--=======4D81A29=======
Content-Type: text/plain; x-avg-checked=avg-ok-52D957A8; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
Norman,
Thanks, you got me pointed in the correct direction! I had an old (7.0)
version of libpq.dll in my path. Using the version you included in
libpq.lib.tgz fixed my problem.
Thank you very much,
Rich
At 09:25 PM 2/9/2003 -0500, you wrote:
>Richard Greenwood writes:
> > The postgis table works correctly with mapserver under Linux, these errors
> > only occur under windows. In both cases I am pulling the data off of the
> > same PostgreSQL 7.2 database.
>FYI
>My libpq package was built from the PostgreSQL 7.3.1 source tree
>I have no idea if that makes a differeance
>You could ask about this on one of the postgres lists
>Norman
Richard W. Greenwood, PLS
(307) 733-0203
Rich at GreenwoodMap.com
www.GreenwoodMap.com
--=======4D81A29=======--
