[Mapserver-users] win32 postgis
Paul Ramsey
pramsey at refractions.net
Sun Feb 9 22:11:59 EST 2003
The old (< 7.2) libpq versions had an upper limit for result set size
build in (win32 only, don't know why). After your posting I was hunting
around my 7.3 code and could not find one... now I know why. :)
P.
Richard Greenwood wrote:
> Norman,
> Thanks, you got me pointed in the correct direction! I had an old (7.0)
> version of libpq.dll in my path. Using the version you included in
> libpq.lib.tgz fixed my problem.
> Thank you very much,
> Rich
> At 09:25 PM 2/9/2003 -0500, you wrote:
>> Richard Greenwood writes:
>> > The postgis table works correctly with mapserver under Linux, these
>> errors
>> > only occur under windows. In both cases I am pulling the data off of
>> the
>> > same PostgreSQL 7.2 database.
>> FYI
>> My libpq package was built from the PostgreSQL 7.3.1 source tree
>> I have no idea if that makes a differeance
>> You could ask about this on one of the postgres lists
>> Norman
> Richard W. Greenwood, PLS
> (307) 733-0203
> Rich at GreenwoodMap.com
> www.GreenwoodMap.com
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
