[Mapserver-users] Can't seem to get the projection correct
Ed McNierney
ed at topozone.com
Tue Feb 18 12:54:39 EST 2003
FYI - I just checked the MapServer image, too. The 11 degrees of
latitude (Manitoba) take up 82 pixels, or 7.45 pixels per degree. The
12 degrees of longitude (CO/UT) take up 89 pixels, or 7.42 pixels per
degree. MapServer is producing the correct result.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
From: Richard Greenwood [mailto:Rich at GreenwoodMap.com]
Sent: Tuesday, February 18, 2003 12:41 PM
To: Martin, Daniel
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Can't seem to get the projection correct
At 10:51 AM 2/18/2003 -0600, you wrote:
>Well, perhaps MapInfo is lying to me, but it says the projection I am
after
>*is* latlong. It says: "Latitude/Longitude (NAD 27 for the
Continental
>US)"
Did you get that from MapInfo > Table > Maintenance > Projection? Or
from
MapInfo > Map > Options > Projection? The first method will tell you
what
that specific table's projection is, but in the second case, MapInfo may
"lie" to you because it reprojects tables to the projection of the
current
map window.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
