[Mapserver-users] Gmap75 demo - gd - freetype problem
Lars Schylberg
lars.schylberg at sssk.se
Sun Feb 23 06:27:28 EST 2003
--------------020608030403010706000400
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
I have just managed to set up mapserver on our linux machine linux 7.3
When I try and run the mapscript demo gmap75 I get the following error.
Warning: MapServer Error in msGetLabelSize(): libgd was not built with
FreeType font support in
.... /gmap/htdocs/gmap75.php3 on line 548
Fatal error: Call to a member function on a non-object in ....
/gmap/htdocs/gmap75.php3 on line 549
My phpinfo_mapscript.phtml tells the following:
MapScript
MapScript Version ($Revision: 1.104.2.5 $ $Date: 2002/10/28 21:47:53 $)
MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7
INPUT=JPEG INPUT=GDAL INPUT=SHAPEFILE
GD Support enabled
GD Version bundled (2.0 compatible)
FreeType Support enabled
FreeType Linkage with TTF library
GIF Read Support enabled
PNG Support enabled
WBMP Support enabled
Could some try and explain what is wrong. Is there a problem with gd2.
I have compiled the latest
2.0.11. We are running only phtml as cgi. All other extensions are
modules. I have not recompiled php.
But I have removed the old gd as told in the examples on
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH73
Hope someone can help med out.
Lars Schylberg
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
I have just managed to set up mapserver on our linux machine linux 7.3 <br>
When I try and run the mapscript demo gmap75 I get the following error.<br>
<br>
<b>Warning</b>: MapServer Error in msGetLabelSize(): libgd was not built
with FreeType font support in<br>
<br>
.... <b>/gmap/htdocs/gmap75.php3</b> on line <b>548</b><br>
<br>
<b>Fatal error</b>: Call to a member function on a non-object in ....
<b>/gmap/htdocs/gmap75.php3</b> on line <b>549</b><a
name="module_MapScript"><br>
<br>
My phpinfo_mapscript.phtml tells the following:<br>
<br>
MapScript</a> <br>
<br>
MapScript Version ($Revision: 1.104.2.5 $ $Date: 2002/10/28 21:47:53 $)<br>
SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=JPEG
INPUT=GDAL INPUT=SHAPEFILE<br>
<table border="0" cellpadding="3" width="600">
<tbody>
<tr>
<td class="e">GD Support </td>
<td class="v">enabled </td>
</tr>
<tr>
<td class="e">GD Version </td>
<td class="v">bundled (2.0 compatible) </td>
</tr>
<tr>
<td class="e">FreeType Support </td>
</tr>
<tr>
<td class="e">FreeType Linkage </td>
<td class="v">with TTF library </td>
</tr>
<tr>
<td class="e">GIF Read Support </td>
</tr>
<tr>
<td class="e">PNG Support </td>
</tr>
<tr>
<td class="e">WBMP Support </td>
<td class="v">enabled</td>
</tr>
</tbody>
</table>
<br>
Could some try and explain what is wrong. Is there a problem with gd2. I
have compiled the latest<br>
2.0.11. We are running only phtml as cgi. All other extensions are modules.
I have not recompiled php.<br>
But I have removed the old gd as told in the examples on <a class="moz-txt-link-freetext" href="http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH73">http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH73</a><br>
<br>
Hope someone can help med out.<br>
<br>
Lars Schylberg<br>
<br>
</body>
</html>
--------------020608030403010706000400--
