[Mapserver-users] Gmap75 demo - gd - freetype problem
Daniel Morissette morissette at dmsolutions.ca
Sun Feb 23 09:21:53 EST 2003
Is it possible that PHP and MapScript are not compiled with the same
version of GD?  The phpinfo() information seems to report that Freetype
is included, but perhaps the GD that was used to compile MapServer (or
the libgd.so that MapServer finds at runtime) is another version that
was not compiled with TTF.  (Make sure you really have only one version
of GD on your system)
Or perhaps the problem is related to using GD 2 with MapServer 3.6.x.  I
have only used GD 1.x with MapServer 3.6 so I don't know if things will
work fine with GD 2.
Daniel
> Lars Schylberg wrote:
> I have just managed to set up mapserver on our linux machine linux 7.3
> When I try and run the mapscript demo gmap75 I get the following
> error.
> Warning: MapServer Error in msGetLabelSize(): libgd was not built with
> FreeType font support in
>     ....    /gmap/htdocs/gmap75.php3 on line 548
> Fatal error: Call to a member function on a non-object in  ....
>  /gmap/htdocs/gmap75.php3 on line 549
> My phpinfo_mapscript.phtml tells the following:
> MapScript
> MapScript Version ($Revision: 1.104.2.5 $ $Date: 2002/10/28 21:47:53
> MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> INPUT=EPPL7 INPUT=JPEG INPUT=GDAL INPUT=SHAPEFILE
>  GD Support                    enabled
>  GD Version                    bundled (2.0 compatible)
>  FreeType Support              enabled
>  FreeType Linkage              with TTF library
>  GIF Read Support              enabled
>  PNG Support                   enabled
>  WBMP Support                  enabled
> Could some try and explain what is wrong.  Is there a problem with
> gd2. I have compiled the latest
> 2.0.11.   We are running only phtml as cgi.  All other extensions are
> modules. I have not recompiled php.
> But I have removed the old gd as told in the examples on
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH73
> Hope someone can help med out.
> Lars Schylberg
