[Mapserver-users] Random Issues
William Carty admin at thinktankdecoy.com
Mon Feb 24 20:24:21 EST 2003
Hello,
I'm not a GIS person, but I'm trying my best :)
For the past few weeks, I've been working on getting the phpGIS
(http://www.phpgis.org) application up & running for our county GIS
department.  This app uses mapscript as the backend.
In deploying & testing I've run across a few issues I'd like to bring up
here.  I've done (or am doing) my best to find an answer on my own, but
obviously haven't in every case...
1.  "MapServer Error in msDrawShape":
      I'm having a problem with one of my layers (roads).  The layer is
a line shape & does not work at the full extent of the map (zoomed all
the way out).  When I try to view this layer at the full extent, I get
the error: "Warning: MapServer Error in msDrawShape(): Only polygon or
line shapes can be drawn using a line layer definition."  Now, if I set
the MAXSCALE attribute in the map file so that the roads layer is only
visible after zooming in, the layer works fine.  Also, if I change the
layer to a point instead of line, it works fine at any extent.
Based on what I've read in the archives, it looks like others have had
this problem.  The fix I've read about has been to "clean up" the
arcview shapefile.  I've had our GIS folks "clean it up" as much as they
say they can, but the problem still exists.  Is there anything else I
can do to get around this?  I really want to have the roads displayed at
the full extent, but don't want to have to use a point layer.
2.  Railroads
     This may seem like a silly question, but what sort of symbols /
images do you folks use to represent railroad tracks?  I've tried making
a few symbols by hand, but nothing looks quite right :).  I'd rather not
use a regular line, I'd rather have railroad tracks.
3.  Fonts / Labels
     I'm still reading the how-to's, but I thought I'd go ahead & throw
this one out.  So far as I can tell, there isn't much I need to do to
get fonts to work for text labels.  Basically copy them over, create the
fontlist file & then create the pointer in the map file.  Is this
basically correct, or are there any gotchas I should watch out for when
setting this up?  (On a Linux box)
Think that's about it for now.
Thanks!
Will
William Carty
Washington County Virginia
Webmaster
Department of Information Technology
