FW: [Mapserver-users] Random Issues
Benjamin Wragg
bwragg at tpg.com.au
Mon Feb 24 23:17:44 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0009_01C2DCDC.DBA5B0A0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi Will,
For question 2 on Railroads, there was something recently on the list
regarding this. Check out
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0302/msg00317.h
tml
Cheers,
Benjamin Wragg
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of William
Carty
Sent: Tuesday, 25 February 2003 11:54 AM
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Random Issues
Hello,
I'm not a GIS person, but I'm trying my best :)
For the past few weeks, I've been working on getting the phpGIS
(http://www.phpgis.org) application up & running for our county GIS
department. This app uses mapscript as the backend.
In deploying & testing I've run across a few issues I'd like to bring up
here. I've done (or am doing) my best to find an answer on my own, but
obviously haven't in every case...
1. "MapServer Error in msDrawShape":
I'm having a problem with one of my layers (roads). The layer is
a line shape & does not work at the full extent of the map (zoomed all
the way out). When I try to view this layer at the full extent, I get
the error: "Warning: MapServer Error in msDrawShape(): Only polygon or
line shapes can be drawn using a line layer definition." Now, if I set
the MAXSCALE attribute in the map file so that the roads layer is only
visible after zooming in, the layer works fine. Also, if I change the
layer to a point instead of line, it works fine at any extent.
Based on what I've read in the archives, it looks like others have had
this problem. The fix I've read about has been to "clean up" the
arcview shapefile. I've had our GIS folks "clean it up" as much as they
say they can, but the problem still exists. Is there anything else I
can do to get around this? I really want to have the roads displayed at
the full extent, but don't want to have to use a point layer.
2. Railroads
This may seem like a silly question, but what sort of symbols /
images do you folks use to represent railroad tracks? I've tried making
a few symbols by hand, but nothing looks quite right :). I'd rather not
use a regular line, I'd rather have railroad tracks.
3. Fonts / Labels
I'm still reading the how-to's, but I thought I'd go ahead & throw
this one out. So far as I can tell, there isn't much I need to do to
get fonts to work for text labels. Basically copy them over, create the
fontlist file & then create the pointer in the map file. Is this
basically correct, or are there any gotchas I should watch out for when
setting this up? (On a Linux box)
Think that's about it for now.
Thanks!
Will
William Carty
Washington County Virginia
Webmaster
Department of Information Technology
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: message/rfc822
Content-Disposition: attachment
Sender: <mapserver-users-admin at lists.gis.umn.edu>
To: <mapserver-users at lists.gis.umn.edu>
Subject: RE: [Mapserver-users] Train line
Date: Fri, 14 Feb 2003 01:57:06 +1030
Message-ID: <ACFEE944B85ED611AEC800B0D0FCEB4B8C8BE6 at mail3.oulan.ou.edu>
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_NextPart_000_0000_01C2DCDC.DBA33FA0"
X-Mailer: Internet Mail Service (5.5.2656.59)
X-From_: mapserver-users-admin at lists.gis.umn.edu Fri Feb 14 02:35:12 2003
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
List-Help: <mailto:mapserver-users-request at lists.gis.umn.edu?subject=help>
List-Subscribe: <http://lists.gis.umn.edu/mailman/listinfo/mapserver-users>,<mailto:mapserver-users-request at lists.gis.umn.edu?subject=subscribe>
List-Unsubscribe: <http://lists.gis.umn.edu/mailman/listinfo/mapserver-users>,<mailto:mapserver-users-request at lists.gis.umn.edu?subject=unsubscribe>
X-Mailman-Version: 2.0.13
X-BeenThere: mapserver-users at lists.gis.umn.edu
------=_NextPart_000_0000_01C2DCDC.DBA33FA0
charset="iso-8859-1"
I'd been needing a RR symbol (although not bad enough to mess with it)
and
this takes care of me. Next time someone looks in the archives (unless
this
is already there) I think they will be pleased.
Thanks
Dave
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Wednesday, February 12, 2003 3:17 PM
> To: Martin, Daniel
> Cc: 'Juanse'; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Train line
> Daniel is correct. There is no way to get the actual
> hatched-line rail
> symbol.
> However.
> Here is a half-assed approximation. By overlaying a 3-pixel dot on a
> one-pixel line every 7 pixels you get something which looks somewhat
> like the classic train symbology.
> CLASS
> NAME "Rail Lines"
> COLOR 0 0 0
> OVERLAYSYMBOL dashed2
> OVERLAYCOLOR 0 0 0
> OVERLAYSIZE 3
> END
> SYMBOL
> NAME "dashed2"
> TYPE ellipse
> POINTS
> 1 1
> END
> STYLE
> 1 7
> END
> END
> Martin, Daniel wrote:
> > Not to shirk you off, but I would suggest searching the
> mail archives
> > for the word "train". The subject has been discussed several times
> > before, and several attempted solutions were mentioned.
> Though, I'm
> > quite sure the answer has come back every time as "no". I believe
> > that with the current version of MapServer there is no good way to
> > achieve the classic train symbology.
> > -Dan Martin
> > From: Juanse [mailto:georef at tie.cl]
> > Sent: Wednesday, February 12, 2003 2:38 PM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] Train line
> > Any one have drawn a train line? the clasical black
> > ----+----+---+---+---+ more or less? or a better one? can you share
> > the symbol? is there a url to see posibilities?
> > juanse
> > temuko-Chile
> > Outgoing mail is certified Virus Free.
> > Checked by AVG anti-virus system (http://www.grisoft.com).
> > Version: 6.0.449 / Virus Database: 251 - Release Date: 27/01/03
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
6.0.4630.0">
<TITLE>RE: [Mapserver-users] Train line</TITLE>
</HEAD>
<BODY>
<!-- Converted from text/plain format -->
<P><FONT SIZE=3D2>I'd been needing a RR symbol (although not bad enough =
to mess with it) and</FONT>
<BR><FONT SIZE=3D2>this takes care of me. Next time someone looks in the =
archives (unless this</FONT>
<BR><FONT SIZE=3D2>is already there) I think they will be =
pleased.</FONT>
</P>
<P><FONT SIZE=3D2>Thanks</FONT>
</P>
<P><FONT SIZE=3D2>Dave</FONT>
</P>
<P><FONT SIZE=3D2>> -----Original Message-----</FONT>
<BR><FONT SIZE=3D2>> From: Paul Ramsey [<A =
HREF=3D"mailto:pramsey at refractions.net">mailto:pramsey at refractions.net</A=
>] </FONT>
<BR><FONT SIZE=3D2>> Sent: Wednesday, February 12, 2003 3:17 =
PM</FONT>
<BR><FONT SIZE=3D2>> To: Martin, Daniel</FONT>
<BR><FONT SIZE=3D2>> Cc: 'Juanse'; =
mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>> Subject: Re: [Mapserver-users] Train line</FONT>
<BR><FONT SIZE=3D2>> </FONT>
<BR><FONT SIZE=3D2>> Daniel is correct. There is no way to get the =
actual </FONT>
<BR><FONT SIZE=3D2>> hatched-line rail </FONT>
<BR><FONT SIZE=3D2>> symbol.</FONT>
<BR><FONT SIZE=3D2>> However.</FONT>
<BR><FONT SIZE=3D2>> Here is a half-assed approximation. By =
overlaying a 3-pixel dot on a </FONT>
<BR><FONT SIZE=3D2>> one-pixel line every 7 pixels you get something =
which looks somewhat </FONT>
<BR><FONT SIZE=3D2>> like the classic train symbology.</FONT>
<BR><FONT SIZE=3D2>> CLASS</FONT>
<BR><FONT SIZE=3D2>> NAME "Rail Lines"</FONT>
<BR><FONT SIZE=3D2>> COLOR 0 0 0</FONT>
<BR><FONT SIZE=3D2>> OVERLAYSYMBOL dashed2</FONT>
<BR><FONT SIZE=3D2>> OVERLAYCOLOR 0 0 0</FONT>
<BR><FONT SIZE=3D2>> OVERLAYSIZE 3</FONT>
<BR><FONT SIZE=3D2>> END</FONT>
<BR><FONT SIZE=3D2>> SYMBOL</FONT>
<BR><FONT SIZE=3D2>> NAME "dashed2"</FONT>
<BR><FONT SIZE=3D2>> TYPE ellipse</FONT>
<BR><FONT SIZE=3D2>> POINTS</FONT>
<BR><FONT SIZE=3D2>> 1 1</FONT>
<BR><FONT SIZE=3D2>> STYLE</FONT>
<BR><FONT SIZE=3D2>> 1 7</FONT>
<BR><FONT SIZE=3D2>> Martin, Daniel wrote:</FONT>
<BR><FONT SIZE=3D2>> > Not to shirk you off, but I would suggest =
searching the </FONT>
<BR><FONT SIZE=3D2>> mail archives </FONT>
<BR><FONT SIZE=3D2>> > for the word "train". The =
subject has been discussed several times </FONT>
<BR><FONT SIZE=3D2>> > before, and several attempted solutions =
were mentioned. </FONT>
<BR><FONT SIZE=3D2>> Though, I'm </FONT>
<BR><FONT SIZE=3D2>> > quite sure the answer has come back every =
time as "no". I believe </FONT>
<BR><FONT SIZE=3D2>> > that with the current version of MapServer =
there is no good way to </FONT>
<BR><FONT SIZE=3D2>> > achieve the classic train symbology.</FONT>
<BR><FONT SIZE=3D2>> > </FONT>
<BR><FONT SIZE=3D2>> > -Dan Martin</FONT>
<BR><FONT SIZE=3D2>> > -----Original Message-----</FONT>
<BR><FONT SIZE=3D2>> > From: Juanse [<A =
HREF=3D"mailto:georef at tie.cl">mailto:georef at tie.cl</A>]</FONT>
<BR><FONT SIZE=3D2>> > Sent: Wednesday, February 12, 2003 2:38 =
PM</FONT>
<BR><FONT SIZE=3D2>> > To: =
<BR><FONT SIZE=3D2>> > Subject: [Mapserver-users] Train =
line</FONT>
<BR><FONT SIZE=3D2>> > Any one have drawn a train line? the =
clasical black </FONT>
<BR><FONT SIZE=3D2>> > ----+----+---+---+---+ more or less? or a =
better one? can you share </FONT>
<BR><FONT SIZE=3D2>> > the symbol? is there a url to see =
posibilities?</FONT>
<BR><FONT SIZE=3D2>> > juanse</FONT>
<BR><FONT SIZE=3D2>> > temuko-Chile</FONT>
<BR><FONT SIZE=3D2>> > ---</FONT>
<BR><FONT SIZE=3D2>> > Outgoing mail is certified Virus =
Free.</FONT>
<BR><FONT SIZE=3D2>> > Checked by AVG anti-virus system (<A =
HREF=3D"http://www.grisoft.com">http://www.grisoft.com</A>).</FONT>
<BR><FONT SIZE=3D2>> > Version: 6.0.449 / Virus Database: 251 - =
Release Date: 27/01/03 </FONT>
<BR><FONT SIZE=3D2>> > =
_______________________________________________</FONT>
<BR><FONT SIZE=3D2>> > Mapserver-users mailing list =
Mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>> > <A =
HREF=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http:/=
/lists.gis.umn.edu/mailman/listinfo/mapserver-users</A></FONT>
<BR><FONT SIZE=3D2>> -- </FONT>
<BR><FONT SIZE=3D2>> =
__</FONT>
<BR><FONT SIZE=3D2>> /</FONT>
<BR><FONT SIZE=3D2>> | Paul =
Ramsey</FONT>
<BR><FONT SIZE=3D2>> | =
Refractions Research</FONT>
<BR><FONT SIZE=3D2>> | Email: =
pramsey at refractions.net</FONT>
<BR><FONT SIZE=3D2>> | Phone: =
(250) 885-0632</FONT>
<BR><FONT SIZE=3D2>> \_</FONT>
<BR><FONT SIZE=3D2>> Mapserver-users mailing list</FONT>
<BR><FONT SIZE=3D2>> Mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>> <A =
<BR><FONT =
SIZE=3D2>_______________________________________________</FONT>
<BR><FONT SIZE=3D2>Mapserver-users mailing list</FONT>
<BR><FONT SIZE=3D2>Mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2><A =
</P>
</BODY>
</HTML>
------=_NextPart_000_0000_01C2DCDC.DBA33FA0--
To: "Martin, Daniel" <DMartin at erac.com>
Cc: "'Juanse'" <georef at tie.cl>,
References: <4ACBA1414DD9EE418CC250E4AAA9035AADBD6E at STL-EXBE-I03.corp.erac.com>
Date: Thu, 13 Feb 2003 07:46:42 +1030
Message-ID: <3E4AB9BA.9000906 at refractions.net>
MIME-Version: 1.0
boundary="----=_NextPart_000_0004_01C2DCDC.DBA5B0A0"
X-Mailer: Microsoft Outlook, Build 10.0.4024
X-From_: mapserver-users-admin at lists.gis.umn.edu Thu Feb 13 08:24:47 2003
X-Accept-Language: en-us, en
In-Reply-To: <4ACBA1414DD9EE418CC250E4AAA9035AADBD6E at STL-EXBE-I03.corp.erac.com>
X-Spam-Level:
X-Spam-Status: No, hits=-3.2 required=5.0tests=IN_REP_TO,QUOTED_EMAIL_TEXT,REFERENCES, SIGNATURE_SHORT_DENSE,SPAM_PHRASE_01_02,USER_AGENT, USER_AGENT_MOZILLA_UA,X_ACCEPT_LANGversion=2.44
------=_NextPart_000_0004_01C2DCDC.DBA5B0A0
charset="us-ascii"
Daniel is correct. There is no way to get the actual hatched-line rail
symbol.
However.
CLASS
NAME "Rail Lines"
COLOR 0 0 0
OVERLAYCOLOR 0 0 0
OVERLAYSIZE 3
END
SYMBOL
NAME "dashed2"
TYPE ellipse
POINTS
1 1
END
STYLE
1 7
END
END
> Not to shirk you off, but I would suggest searching the mail archives
for
before, and
> several attempted solutions were mentioned. Though, I'm quite sure
the
> answer has come back every time as "no". I believe that with the
current
> version of MapServer there is no good way to achieve the classic train
> symbology.
> -Dan Martin
> more or less? or a better one? can you share the symbol? is there a
url to
> see posibilities?
> juanse
> temuko-Chile
__
| Paul Ramsey
\_
charset="us-ascii"
<HTML>
<HEAD>
charset=3Dus-ascii">
6.0.4630.0">
<TITLE>Re: [Mapserver-users] Train line</TITLE>
</HEAD>
<BODY>
<P><FONT SIZE=3D2>Daniel is correct. There is no way to get the actual =
<BR><FONT SIZE=3D2>symbol.</FONT>
</P>
<P><FONT SIZE=3D2>However.</FONT>
</P>
<P><FONT SIZE=3D2>Here is a half-assed approximation. By overlaying a =
<BR><FONT SIZE=3D2>one-pixel line every 7 pixels you get something which =
<BR><FONT SIZE=3D2>like the classic train symbology.</FONT>
</P>
<P><FONT SIZE=3D2>CLASS</FONT>
<BR><FONT SIZE=3D2> NAME "Rail Lines"</FONT>
<BR><FONT SIZE=3D2> COLOR 0 0 0</FONT>
<BR><FONT SIZE=3D2> OVERLAYSYMBOL dashed2</FONT>
<BR><FONT SIZE=3D2> OVERLAYCOLOR 0 0 0</FONT>
<BR><FONT SIZE=3D2> OVERLAYSIZE 3</FONT>
<BR><FONT SIZE=3D2>END</FONT>
</P>
<P><FONT SIZE=3D2>SYMBOL</FONT>
<BR><FONT SIZE=3D2> NAME "dashed2"</FONT>
<BR><FONT SIZE=3D2> TYPE ellipse</FONT>
<BR><FONT SIZE=3D2> POINTS</FONT>
<BR><FONT SIZE=3D2> 1 1</FONT>
<BR><FONT SIZE=3D2> END</FONT>
<BR><FONT SIZE=3D2> STYLE</FONT>
<BR><FONT SIZE=3D2> 1 7</FONT>
</P>
<P><FONT SIZE=3D2>Martin, Daniel wrote:</FONT>
<BR><FONT SIZE=3D2>> Not to shirk you off, but I would suggest =
searching the mail archives for</FONT>
<BR><FONT SIZE=3D2>> the word "train". The subject =
has been discussed several times before, and</FONT>
<BR><FONT SIZE=3D2>> several attempted solutions were =
mentioned. Though, I'm quite sure the</FONT>
<BR><FONT SIZE=3D2>> answer has come back every time as =
"no". I believe that with the current</FONT>
<BR><FONT SIZE=3D2>> version of MapServer there is no good way to =
achieve the classic train</FONT>
<BR><FONT SIZE=3D2>> symbology.</FONT>
<BR><FONT SIZE=3D2>> -Dan Martin</FONT>
<BR><FONT SIZE=3D2>> -----Original Message-----</FONT>
<BR><FONT SIZE=3D2>> From: Juanse [<A =
<BR><FONT SIZE=3D2>> Sent: Wednesday, February 12, 2003 2:38 =
PM</FONT>
<BR><FONT SIZE=3D2>> To: mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>> Subject: [Mapserver-users] Train line</FONT>
<BR><FONT SIZE=3D2>> Any one have drawn a train line? the clasical =
black ----+----+---+---+---+</FONT>
<BR><FONT SIZE=3D2>> more or less? or a better one? can you share the =
symbol? is there a url to</FONT>
<BR><FONT SIZE=3D2>> see posibilities?</FONT>
<BR><FONT SIZE=3D2>> juanse</FONT>
<BR><FONT SIZE=3D2>> temuko-Chile</FONT>
<BR><FONT SIZE=3D2>> ---</FONT>
<BR><FONT SIZE=3D2>> Outgoing mail is certified Virus Free.</FONT>
<BR><FONT SIZE=3D2>> Checked by AVG anti-virus system (<A =
<BR><FONT SIZE=3D2>> Version: 6.0.449 / Virus Database: 251 - Release =
Date: 27/01/03</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>-- </FONT>
<BR><FONT SIZE=3D2> __</FONT>
<BR><FONT SIZE=3D2> /</FONT>
<BR><FONT SIZE=3D2> | Paul Ramsey</FONT>
<BR><FONT SIZE=3D2> | Refractions =
Research</FONT>
<BR><FONT SIZE=3D2> | Email: =
<BR><FONT SIZE=3D2> | Phone: (250) =
885-0632</FONT>
<BR><FONT SIZE=3D2> \_</FONT>
</P>
<P><FONT SIZE=3D2>_______________________________________________</FONT>
</P>
</BODY>
</HTML>
------=_NextPart_000_0004_01C2DCDC.DBA5B0A0--
------=_NextPart_000_0009_01C2DCDC.DBA5B0A0--
