[Mapserver-users] Projecting Rasters 3.7
Fri Feb 28 12:01:56 EST 2003
randy james wrote:
> Hi
> I thought i should report this, in case no one else
> notices it right away.
> I was trying the nightly from Feb 27 2003 and noticed
> that when zooming in, with raster layers on, that are
> projected, the projection was not working correctly.
> The raster seemed to shift around as i zoomed in
> (quite a bit, around 500M).
> I am now using the nightly from feb 21 which works
> fine.
Randy,
Yikes!  This is likely my fault as I reworked some stuff about the
raster resampling code on the 24th.  I will try to reproduce and fix this,
but if I can't reproduce it I will get back to you for suggestions on how
to see the error.
Best regards,
