[Mapserver-users] Compile issues, no PNG's
Madere, Colin colin.madere at ieminc.com
Fri Feb 28 12:03:40 EST 2003
This may or may not be your issue, but thought it worth mentioning.
With the new version of the graphics libraries (gdal I think?), GIF support
is not included because of all the licensing crap.  However, the demo that
comes with 3.6.4 is set up to specifically use GIF files.  I didn't have a
GIF library so I couldn't run the demo (and don't know enough about
mapserver to change the demo to use PNGs).
> -----Original Message-----
> From:	Marc Drouin [SMTP:marc.drouin at fondex.ca]
> Sent:	Friday, February 28, 2003 10:43 AM
> To:	mapserver-users at lists.gis.umn.edu
> Subject:	[Mapserver-users] Compile issues, no PNG's
> Hi group,
> I just recompiled mapserver to incorporate Postgis functionnalities.  When
> I try the demo, which used to work fine before, the CGI does not generate
> an image.  The directory where the images are supposed to be sent did not
> change, nor the permissions (same demo set up, different mapserver).  I
> compile mapserver, postgresql and postgis as root.  cgi-bin is set for
> read and execute and so is mapserv.  Anyways, i'm stumped.
> Ca anyone help me.
> Marc
> P.S. if this can help....
> Linux 8.0
> mapserver 3.6.4
> postgresql 7.2.2
> postgis 0.7.4
